The 07 S60 2.5T fan will squeak when the car is moving forward from a stop or coming to a stop. Bearing is sloppy but hoping it's still be okay with some lube. Can't wait for warmer weather.
noisy blower fan
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
It is warm now in North Carolina, why are you complaining?MoVolvos wrote: 06 Feb 2026, 16:56 .
- MoVolvos
.vtl wrote: 06 Feb 2026, 17:12It is warm now in North Carolina, why are you complaining?MoVolvos wrote: 06 Feb 2026, 16:56 .
Cold if you lived most of your life in CA
vtl
Sorry to hear that, man... I send your way a virtual bread, beer and bacon.MoVolvos wrote: 06 Feb 2026, 17:48 Cold if you lived most of your life in CA. Just when I start getting use to the heat or cold the season is over. I've also lost 20 lbs within perhaps 6 weeks 3 months back due to the cancer so I'm still skin and bones
- Has thanked: 1611 times
- Been thanked: 4075 times
That makes a SNR OF SQRT(1) = 1br0dy519 wrote: 06 Feb 2026, 10:57@abscate please note a sample size of n=1erikv11 wrote: 03 Feb 2026, 15:43On my S60, the blower motor started whistling in the winter of 2018. I still haven't replaced it (viewtopic.php?p=643927&hilit=garage#p643927). Sound never got much worse, and it makes no noise at all in warm months. Just one data point and YMMV, but FYI.erikv11 wrote: 03 Feb 2026, 11:16 It is already warming up, you can forget about it until next winter!![]()
- Been thanked: 504 times
I have saved many electrical motors by lubricating the bushings. Very often, ppl call it "bearing", but it is essentially a "bushing", a cost-cutting measure in places with light load and simply spinning around. A bushing is cheaper than ball bearing:
- Portable electrical space heater...1 drop of oil every 5-7 years.
- Hair dryer motor...
- I have an old Bosch clothes dryer...same thing...1 drop of oil every 5-7 years.
- The only problem with Volvo (or any car) blower motor...
it is a contortionist position you assume to get it out of the car: it is not a pleasant job as you get older.
Once the blower motor is on a bench, it is VERY EASY to lubricate it. I showed the tricks in 2005 XC90 forum: I did it almost 10 yrs ago, so far so good.
Another benefit of lubricating the motor shaft...1 less item going to landfill site...
I managed to silicone spray lube my p2 blower which would chirp on deceleration only. Still good
- Been thanked: 818 times
This is a great idea, give it a quick spray in situ. I might actually try it! Maybe next cabin filter change.abscate wrote: 08 Feb 2026, 08:41 I managed to silicone spray lube my p2 blower which would chirp on deceleration only. Still good
I searched and couldnβt find this job. Did I make this up in my head? My blower definitely was noisy and now it isnβt. Maybe I replaced it?
- 1149 Views
Last post by oragex
- 14 Replies
- 5018 Views
Last post by bichinavolvo
- 46 Replies
- 12923 Views
Last post by 93Regina
- 560 Views
Last post by sandyegg
- 1190 Views
