It’s that and the consistency of assembly that make them the choice on new carskallekula wrote: 15 Jul 2022, 11:55 Isn’t the thing with oetikers that they adjust to the crimping aging hose it’s clamping onto. Oetikers is like a “spring” sort of. Leaks develop later than traditional screw clamps.
I’m bad at screw clamps. Anybody use Oetiker clamps?
- Has thanked: 1611 times
- Been thanked: 4072 times
- kallekula
- Year and Model: S70 2000
- Has thanked: 58 times
- Been thanked: 75 times
They’re much faster to fasten compared to a screw clamp.
BMW 540i 2002
S70 Base 2000
And much faster to remove, too.
Zip zip zip
Zip zip zip
- FireFox31
- Has thanked: 159 times
- Been thanked: 303 times
How do you easily remove an Oetiker clamp? I have to fight them with a flat head screwdriver. The results aren't pretty.
FireFox31
Dr Dremel
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
Great in assembly settings, like a factory.
Not so great in everyday real world settings. And not re-usable. Might as well use a zip-tie.
1999 V70 GLT
1999 V70 GLT
- kallekula
There are a few tricks. Checkout youtubes.FireFox31 wrote: 15 Jul 2022, 14:28 How do you easily remove an Oetiker clamp? I have to fight them with a flat head screwdriver. The results aren't pretty.
BMW 540i 2002
S70 Base 2000
- kallekula
Zip ties get brittle with time (and heat).Do it right from the beginning and there will be no reason to revisit the problem again…
BMW 540i 2002
S70 Base 2000
Dr Dremel is not going to fuss with stripped clamp heads and ugly clamps , no mo’
I didn’t even bring the screwdriver underneath when I saw that
Also, $450 in labor saved from dealer…
- 14 Replies
- 1625 Views
Last post by BEJinFbk
- 38 Replies
- 13923 Views
Last post by 454cid
- 371 Views
Last post by MarinerMan
- 3057 Views
Last post by yair
- 15 Replies
- 4216 Views
Last post by erikv11
