Ouch! There’s a good example of a snapped P80 axle. Hopefully that doesn’t happen to mine.
New Axle Stuck in Transmission Topic is solved
- Has thanked: 316 times
- Been thanked: 531 times
There is no way a 5 cm steel axle snapped off without a defect..
Probably aftermarket. These things are JUNK!
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
It was 2001 V70XC original - viewtopic.php?f=9&t=62641
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Doesn't look that bad, time to bring the welding machine. But a above, hopefully the carrier bearing & other staff inside didn't take a hit
I've heard it may work rotating a bit then trying to pull, rotate again and so on. Just hope it's not because of a too large size circlip
Being an aftermarket axle, it just might be. We had the same problem with an Autozone axle on my cousin’s S70, but fortunately we got it out.
I didn’t get a chance to work on it today, but I should be able to take care of it tomorrow. I’ll update everyone with what happens!
xHeart
There were many comments against the aftermarket drive axle. CN90 wrote a comprehensive procedure which helped me rebuild too. More here viewtopic.php?f=9&t=62033
This is where I am now... got it out MAYBE another 1/2 mm. I can’t figure out how to get it out without damaging it, as I’d like to try to return it.
- Has thanked: 311 times
- Been thanked: 817 times
##!!#$@@%^@*@&*!^!%$%!#% aftermarket axles.
Seems like an oversize circlip problem, not sure how to remedy that. Seeing the pic I definitely think "needs a huge pickle fork." And clearance.
Maybe a couple of wedges, one on either side, drive them up one by one. You can even try wooden wedges to minimize damage to the trans case but this may be too stuck for that.
- 615 Views
Last post by Blacklab467
- 1501 Views
Last post by TechnicALFA
- 1030 Views
Last post by dsharp
- 441 Views
Last post by Fastlane4
- 22 Replies
- 4389 Views
