cn90, good to see you again. I still owe you for the relay. I'd still be glad to paint a car for you. This is my V70... with a few extra pieces...cn90 wrote: 03 Sep 2019, 19:40 - I always add a tiny bit of wheel bearing grease (about one drop). This way next time it is easier. Have used this trick for 30 years.
- Don't scratch the paint work with your breaker bar!
- A guy on youtube used floor jack to undo the AXLE NUT and it work, see video below...
Loosen ANY lug nut
- dalel
- Year and Model: 1998 V70
- Has thanked: 29 times
- Been thanked: 7 times
- myV70_1.JPG (127.51 KiB) Viewed 1601 times
- amblerman
- Year and Model: 1999 s70
- Has thanked: 2 times
- Been thanked: 70 times
dalel wrote: 03 Sep 2019, 20:36cn90, good to see you again. I still owe you for the relay. I'd still be glad to paint a car for you. This is my V70... with a few extra pieces...cn90 wrote: 03 Sep 2019, 19:40 - I always add a tiny bit of wheel bearing grease (about one drop). This way next time it is easier. Have used this trick for 30 years.
Great picture.. quite a lot of interesting mods going on there.. Can't imagine you get much life out of the tires though.
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
Ultimately the lugs shouldn't be on that tight... In a jam this is a great idea.
2023 Lexus RZ450e -66k
- dalel
Thanks. You can't see the interior mods in that painting... like... I replaced the CEL.amblerman wrote: 04 Sep 2019, 02:47
Great picture.. quite a lot of interesting mods going on there.. Can't imagine you get much life out of the tires though.![]()
- VolvoCEL.jpg (39.35 KiB) Viewed 1570 times
- wizechatmgr
Should replace that with one that says FCP =P
- Been thanked: 504 times
When I buy any used car, this is what I do for the wheels to avoid seized wheels:
1. Jack up each wheel.
2. Remove all the lugs and remove the wheel.
If the wheel is seized onto the hub (snow area with salt), there is trick in forum to undo it, search for the tricks.
3. Apply anti-seize around the hub bore. Also a bit of anti-seize on each lug (about "one drop" of anti-seize).
4. Now your wheel can be replaced in the middle of nowhere without being seized.
- 1093 Views
Last post by zombielinux
- 26 Replies
- 12119 Views
- 4648 Views
Last post by NateTheGreat
- 507 Views
- 609 Views
Last post by jreed
