How do my Delta Link Bushings look to you?
my98s70glt
Year and Model: 99 V70R, 07 V70 2.5T
Has thanked: 11 times
Been thanked: 5 times
Post by my98s70glt »
Current:
1999 V70R: Signal Red/Charcoal || Snabb RIP Kit || Snabb Air Intake || Simons Axleback Dual Exhaust
2007 V70 2.5T: Snabb Fresh Air Pipe || BC Racing Coilovers
Previous: 1998 S70 GLT, 2006 V70 2.5T, 2011 C70 T5, 2012 S60 T5, 2000 S70 GLT/SE
Has thanked: 1609 times
Been thanked: 4065 times
my98s70glt wrote: 26 May 2020, 10:43 FCP has them as well... https://www.fcpeuro.com/products/volvo- ... vo-9995497
I wonder if you bust the tool, is it still under the FCP warranty program?
my98s70glt
abscate wrote: 26 May 2020, 11:34
Funny you should ask... the threaded shaft bent while removing the second bushing (this was before I knew extreme heat was my friend). Since I owned it for a whopping one week and used only on my car they issued me a store credit.
Current:
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
Did this require a breaker bar or an impact driver?
my98s70glt
ZionXIX wrote: 27 May 2020, 05:50 Did this require a breaker bar or an impact driver?
I used a breaker bar, it was a bear of a job without using enough heat to melt the outer plastic shell on the bushing.
Current:
Archer
Year and Model: 2002 V70/S60 T5
Post by Archer »
jonslave wrote: 24 May 2020, 10:16 Car has a lot of miles on it. How do these look guys?
Are these these not the trailing arm bushings...?
jonslave
Year and Model: 1997 855R
Has thanked: 12 times
Post by jonslave »
I used an impact driver rated to 250lb pounds and it got the job done
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
They say not to use an impact driver on those tools...
I run a drill bit through the plastic bushing sleeve on the top of the bushing.
It allows the shell to break away from the arm. Also, it leaves no melted mess.
my98s70glt wrote: 26 May 2020, 15:09
The force required to bend that is crazy...
redbeak1
Year and Model: 850t5 1996
Has thanked: 7 times
Been thanked: 2 times
Post by redbeak1 »
Sveedy wrote: 26 May 2020, 09:02 Just curious - where did you find the delta link removal tool ?
I bought mine from IPD. It was such a challenge getting them out, that I stripped the threads on the tool. I think the picture you are showing is the transverse arm bushings. On my 96 850 the rubber looked good but the metal bracket was broken.
