Vibrations on idle
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Most common cause of vibration after the top torque mount is the front engine mount, the non-hydraulic one under the crank pulley. Access from the wheel well.
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
I would concur with that!
2003 XC 70 (sold)
Kanam102
Year and Model: 2002 S60
Post by Kanam102 »
erikv11 wrote: 18 Feb 2021, 09:24 Most common cause of vibration after the top torque mount is the front engine mount, the non-hydraulic one under the crank pulley. Access from the wheel well.
Blacklab467 wrote: 18 Feb 2021, 10:20 I would concur with that!
I'll try to get my hands on some working space ASAP. Thanks guys! I was trying to find something suspicious in VIDA but I couldn't to. Pic attached, readings of hot engine.
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
change all the coils with new bosch ones, same as volvo but not in the blue box. check the VVT solenoid, these are both common failures.
Google "volvo vvt solenoid symptoms"
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
darrylrobert
My top engine mount is very loose, i can hear the rubber clunk when coasting however at idle i can put a glass of water on the engine and get just a ripple.
Post by erikv11 »
darrylrobert wrote: 18 Feb 2021, 20:48
Congratulations!
Vageloudakis
Year and Model: S60 2007
Has thanked: 2 times
Post by Vageloudakis »
Blacklab467 wrote: 15 Feb 2021, 13:25 Subframe bushings made a huge difference on the engine vibrations that came through the steering wheel. I did the engine mounts ( all 5 ) at the same time. My front hydraulic mount was separated almost completely so that may have been the cause. My XC 70 had 280,000 kms when I did it so all those parts were well past their useful life.
I havw the same problem until saw the normal idle is at 650+/- rpms.
adrian22
Year and Model: s60 2006
Post by adrian22 »
I have exactly same problem with my 2006 V70 engine vibrations much more strong that my other Volvo 2006 s60 that engine runs smooth--same engine on both cars--changed spark plugs and all engine mounts but did not help -synthetic 5x30 oils on both cars-Obviously the engine runs rougher for an reason I dont understand--did you found a solution for your car?
adrian22
