Power steering line
Has thanked: 2210 times
Been thanked: 1852 times
Anyone have any idea what the pressure is in the line? I was thinking along the lines of what abscate has suggested. Drain the line if possible and then split a piece of fuel hose of similar dimension to the holed hose and then clamp it as close as possible to the hole with the rubber hose split on the opposite side to the hole. Then clamp 2 hose clamps as close to the hole as possible. Not a permanent fix but may tide you over the winter.
Depending on the pressure in the hose, could a short section of the metal pipe be removed and a reinforced rubber fuel hose installed in place?
skloon
Year and Model: 94 850 95 850 04 S60
Been thanked: 2 times
Post by skloon »
hmm never thought of that of course the spot is in a hard to access location
Well where is the fun if it was accessible!? The day I get an accessible job will be the first!
