Odometer Gear (Fixed)
A/C Receiver/Drier (Still Broken)
ABS Module (in theory, fixing soon)
Front axle (Caught before failure)
R/F Wheel Bearing hub (Fixed)
Catalytic converter (pipe before broke, failure also broke converter itself)
Rear Oxygen Sensor (possibly broken, related to previous issue)
List your 850/S70/V70/XC70 parts failures, 1992-2000 only
For my 1999 V70 (base model, NA, M/T), here's the big items.
Engine/Drivetrain
- Coil packs went out one by one at approx 160k.
- Steering unit blew the seals and subsequently killed my P/S box at about the same time.
- O2 sensors at 135k
- Alternator at 215k
- Torn CV boots 185k (passenger), 215k (drivers)
- Sway bar end links - 4 times under warranty then twice in the 160k since
Interior
- Driver's side power window switch, twice. At about 80k and 100k.
- Cup holder - somewhere near 120k.
- Factory CD player 180k. Speakers 200k.
- Heater blower 205k
- Heater core 215k
Engine/Drivetrain
Interior
- Heater core 215k
scookstlmo
- Year and Model:
I've got two S70s, one a turbo and one a non-turbo. Of the two, the turbo has been the most problematic with a lot of the listed failures and some that are not listed, e.g. brake master assembly @ 60K, brake booster failed @ 66K, catalytic converter failed @ 79K but dealership wouldn't acknowledge it until after 80K (when the federal emissions warranty expired - thankfully, Volvo Customer Care picked up a good deal of the cost, but left me paying $300). I just had the left sway bar link replaced when the ABS module went out a couple of months ago and this weekend I'm going to replace the wheel hub assembly.
If I were to ever buy another Volvo in the future, it would definitely be a non-turbo, turbos are not worth the aggravation. They are harder on hoses, belts, sensors, etc.
Steven Cook
Jono51
- Year and Model: V70XC, 1999
Here's one that I would think should be very common (on engines with individual coil packs) - ignition coil failure - I've replaced two in the past year.
For a less common one - broken exhaust valve (yes, broken - a piece fell off causing immediate and total loss of compression on the cylinder concerned) the diagnosis was that it was due to carbon build up causing a hot spot on the valve.
If God had meant cars to have fuel injection, he never would have given us the SU carburetter
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
Cupholders...I've gone through a few of them and keep a couple around as spares.
Our s70 has been going through coils left and right. The 850 has been going through it's share of parts, but it is 15 years old.
Master window switch, twice.
Door check.
Everything in the front end.
a few speakers.
Fuel pump
ABS module-pump wiring
Dome light
Rear hatch wiper motor
Rusty sunroof glass/frame
All motor mounts
CD player
Rear hatch lock actuator
Evaporator
Power seat switch
And since I posted this, something will probably happen this week.
Door check.
a few speakers.
Fuel pump
Dome light
All motor mounts
CD player
Evaporator
Power seat switch
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
igel513
- Year and Model: 2003 S60 T5
98 S70 NA 203K miles
Here are the items that have failed;
heater core
SAS valve
PCV system
Inner tie rod end
Front hub bearing
trans. unable to shift out of Park
stabilizer bushing
upper motor mount bushing
cruise control
front spring seats
struts
rear shocks
lower radiator hose
antenna motor
2 hoses connected from block to heater core
R rear window motor
heater core
SAS valve
PCV system
Inner tie rod end
Front hub bearing
stabilizer bushing
cruise control
front spring seats
struts
rear shocks
lower radiator hose
antenna motor
R rear window motor
- 1604 Views
Last post by foggydogg
- 36 Replies
- 7956 Views
Last post by bmdubya1198
- 18 Replies
- 8624 Views
Last post by rspi
- 1373 Views
Last post by clarkerussell
- 23 Replies
- 6234 Views
Last post by oragex
