But does it now work?
Neil
P80 C70 Hvac Drivers side only hot air, damper motor position, map of position counter, internal pictures
- Has thanked: 2196 times
- Been thanked: 1850 times
CoupeC70
- Year and Model: C70 Coupe '01
- Has thanked: 10 times
- Been thanked: 2 times
No, allways hot and slower air from drivers side.
I've just ordered a used ECC unit. To rule that out maybe.
I got fried in the car in today's temperatures... closed the vents on the driver's side to get less fried
CoupeC70
I recently replaced the ECC module, but unfortunately, it didn't fix the issue. Honestly, I should have thought of this earlier and checked the live data first.
Looking at the live data now, itβs clear that the temperature blend door actuator isn't moving at all.
So, I need to replace the actuator. Has anyone here done this before? How difficult of a job is it?
The other problem is that you can't buy these actuators brand new anymore. I'm a bit skeptical about buying a used one, though. Any advice?
Chieber
- Year and Model: 1998 v70
- Has thanked: 69 times
- Been thanked: 49 times
I used this write up to regrease my actuators. It actually worked one ore them. The other one I replaced with a junkyard piece and works flawlessly still.
1/2 a shitbox V70 1998 2.5 NA
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I've repaired and replaced the driver's side actuator. The repair consisted of cleaning off the grease, and it worked well for about 8 years until the carbon traces wore down. Recently I replaced the actuator with a used one and it has been working well for about 1-2 years.
- jreed
It's pretty difficult to access the actuator. The hardest part in my experience is removing two of the three screws that hold it to the side of the center ducting -- they're difficult to see and difficult to remove without dropping them. There have been some detailed descriptions and photos here on MVS that will give you a more in depth view of what's involved. Some of the work has to be done on your side or your back, so you need to be a bit agile.
I found that when I did the first replacement and just cleaned out the actuator, I was able to reinstall it in exactly the same position and calibration was not required.
When I replaced the actuator with a used one, I had to run through the calibration process, which was successful.
- jreed
For removing and installing the actuators, MVS has a page describing one method here:
https://www.matthewsvolvosite.com/ecc-c ... rs-damper/
For cleaning the actuator, there is this MVS post:
viewtopic.php?t=51078
- 13 Replies
- 4194 Views
Last post by BEJinFbk
- 4096 Views
Last post by jvl
- 16 Replies
- 397 Views
Last post by TisMe
- 976 Views
Last post by odaikorob
- 12 Replies
- 2072 Views
Last post by cbarbsnv70
