1998 V70 AWD P0455 P0440 P0442 Fix with Photos
V70 P0455, P0440, P0442 Fix with Photos
joe_pinehill
- Year and Model: 850 1996
To remove the skirt, do simply pull the retainers? They don't have a threaded fastener.
96 850 GLT
RIP '90 240 DL, 285K, someone ran a stop sign in front of me
RIP '89 760 Wagon, 200K
RIP '83 240 Wagon, rusted out
Ben850
- Been thanked: 7 times
I had found a set of the "J/U" hoses from an accident junkyard vehicle which appeared almost new. Lucky me for sure, but I had noticed that there were two zip ties holding the hard plastic hoses, which after clipping gave me plenty wiggle room to deal with the parts.
I was also able to pull the complete plastic tube through the wheel well in case I would need it.
You will need access by opening the fender skirt. The SAS pump is also a bit of a hindrance.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
punkporvida
- Year and Model: V70 1998
Thanks for the great write up!
This was definitely a useful guide to help me find the Evap leak which was throwing code P0442.
My question is when replacing Hose #20 how did you feed the hose over the wheel well (drivers Side fender skrit)? I found that this piece was pretty rigid and didn't really give much. I was able to pull it back enough to get my hands on the shut off valve. But the hose seemed to be pinched or possibly held snug by tension.
How much can the Fender skirt give? Can i really muscle it? or is there a more efficient way to fish the replacement hose into position?
Thanks,
Paddy G
Thanks,
Paddy G
kahl
- Year and Model: 2000V70XC
- Been thanked: 10 times
Following this guide I found a cracked "U" tube on my 2000 V 70 XC above the fuel tank directly behind the fuel filter. Replacing this pipe made P0455 go away.
- image.jpg (244.99 KiB) Viewed 2125 times
deepsouth
- Year and Model: 2001 Volvo XC70
- Been thanked: 11 times
punkporvida wrote:Thanks for the great write up!
Thanks,
Paddy G
I replaced the OEM hard plastic tubing with generic fuel injection hose from AutoZone. Not only was I able to get a much longer length at 1.50 a foot it was much more flexible and bent very easily over the fender skirt.
Eric
2000 S70 GLT SE, 175,000
2001 XC70, 129,000
2001 XC70, 129,000
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
Very interesting thread here...I've spent many hours attempting to extinguish the CEL with PO455. My best guess for now was a slightly leaky shut-off valve, located very close to the canister, which on my car is in the rear, on the pass. side just forward of the right side, rear wheel. The >$120 price of the valve stopped me. Better things to spend money on. I cleaned out the valve, then sprayed in silicone and it worked for about a month or so, then the dredded P0455 returned. I never dropped the tank, but did have a good look through both deck access ports. When I have to get the car inspected, I reset CEL and due to my car being a 98 and some quirk with the timers? taking time for a reset, all the flags don't need to be cleared for me to pass. Dam aggravating though! Great info here!
M1 10W-30 HM
M1 10W-30 HM
Ben850
Paddy,
You being in Texas, hopefully your cold spell is over. The fender skirts are very forgiving and resilient when warm. They usually only may crack when they are very cold.
I got P0442 the other day, reset it and am waiting to see if it comes back (I have been getting the dreaded P0133 for years...). I presume the work in the rear is similar for a non-AWD.
In the meantime, the "Purge valve is located underneath the air duct" picture gives me the creeps: a long metal tool very close to both the positive and negative poles of the battery, yikes!!! Whenever I am under the hood, I cover the battery with a thick rag.
- 4890 Views
Last post by timetobakethedonuts
- 2594 Views
- 52 Replies
- 9638 Views
Last post by bmdubya1198
- 5676 Views
- 23 Replies
- 4723 Views
