Hesitation on WOT (V70 2.0 T5 AWD 1997) Topic is solved
Fiodor
Year and Model: 1997 V70 2.0 T5 AWD
Has thanked: 13 times
Been thanked: 9 times
Post by Fiodor »
Okay, fuel filter replacement didn't change anything :(
1997 V70 T5 2.0 AWD with welded angle gear at 240k km
1990 740 Break (dead)
Fiodor
Post by Fiodor »
This car isn't made to run E85 but I've put on a piggyback device that raises the amount of fuel per injection cycle so that I could have the proper AFR.
And I don't know what ECU is in the car.
I've left it to my mechanic who'll tell me tomorrow if he finds the cause of my issues.
I'll keep you updated, thanks for your help !
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Maybe that device is the source of your problems.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Fiodor
Post by Fiodor »
I've tried unplugging it, didn't change a thing :'(
Fiodor
Post by Fiodor »
Update!
If I run with the MAF unplugged my problems disappear + my fuel consumption drops drastically!
does this make the MAF the definitive culprit?
misha
Post by misha »
Usually...bad Maf have totally different symptoms.
Is Maf that is currently on the car Bosch or something aftermarket?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Fiodor
Post by Fiodor »
Will check this evening and report.
Thanks for bearing with me
misha
Post by misha »
If it is not Bosch...it can cause unusual behaviour....pretending that it's working...but not properly...since aftermarket Maf doesn't have the same values as Bosch(OE) one.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 1612 times
Been thanked: 4075 times
Fiodor wrote: 29 Nov 2018, 05:17 Update!
It might be the MAF or it could be an induction leak after the MAF. When you unplug the MAF, the ECU guesses the air flow by rpm, and it gets pretty close. It will run a bit rich, but it will run well.
Fiodor
Post by Fiodor »
It's a Bosch MAF, the ECU is a moronic 4.4 :)
It feels as if unplugging the MAF causes a performance loss.
The car doesn't stutter but it also doesn't pull as hard...
