Just to add to this excellent DIY, youtube channel "Robinson's Auto Repair" has 4 episodes on 1999 Volvo S70 2.4T Cylinder Head replacement. A lot of good tips:
http://www.youtube.com/user/robinsonsauto/videos
Cylinder Head Replacement
- Been thanked: 504 times
Also,
When you have time, watch this person. This is the only guy that I will feel comfortable to work on my car.
Watch this video How I Got Started Robinsonsauto "chasing a dream":
beoutside
- Year and Model: 1999 xc v70 awd
Just redid the inlaws, same issue blown exhaust value, started right up but has bad exhaust leak......
The manifold was cleaned and checked, I don't think 25nm is much force and I have heard of people warming up the car and retorquing the nuts an extra few lbs to get a seal?
thanks
thanks
1999 V70 x/c AWD
Go Forth and Seek the depths
that create spark in your life......
Or something along those lines
beoutside
On mine the machinist asked to see the cam followers ( lifters) they found one plugged up and another with a broken spring. I had no compression in a cylinder and when I pulled the head I had one blown exhaust valve.
1999 V70 x/c AWD
- Has thanked: 312 times
- Been thanked: 818 times
Clearwater has a web site, www.cylinder-heads.com/
Currently $500 for an 850 head, but I'd call them if working on a turbo.
I have just finished replacing the head gasket on my 1997 850 non turbo. I followed Tracy's instructions and could not have tried to tackle this without them (Thanks Tracy). After completing this and starting the car I noticed excessive smoke from the tailpipe and smoke from the dipstick and the oil fill upon inspection. I completed a compression test of the cylinders and got 160#, 130#, 130#, 150# and 160#. I also did a block leakage test and that showed negative for gases coming through the coolant system. I did not replace the PVC system however I did make sure it was not plugged. Shortly before the head gasket blew I had done the glove test and had vacuum on the dipstick and the oil fill. I am not sure where to go from here. Looking for advice on this. Thanks for any feedback.
- Has thanked: 1611 times
- Been thanked: 4075 times
Put some oil in the cylinders and report wet compression. You might have worn out rings.
Thanks for the reply. I did do a wet compression test on the two cylinders that were low 130 # and it increased to almost 160 #. If the rings are worn would that cause pressure in the dipstick tube and the oil fill? I love the car but its not worth paying someone to rebuild the engine.
Thanks for your help.
Steve
Steve
precopster
- Year and Model: Lots
- Been thanked: 128 times
Perhaps by trying to clean the PCV you actually blocked it. The 130 psi is not healthy and should be between 200 and 210 for a healthy non turbo engine. That factor alone can cause excess blow-by into the crankcase however if it wasn't there to begin with.......
The best service of a PCV is a replacement.
- 13 Replies
- 8507 Views
Last post by lifeofgold
- 2350 Views
Last post by precopster
- 468 Views
Last post by erikv11
- 859 Views
Last post by duckman68
- 16 Replies
- 5311 Views
Last post by RickHaleParker
