cylinder head replacement
duckman68
Year and Model: 1999
Post by duckman68 »
I have a 1999 Volvo v70x/c 2.4l turbo the cylinder head is cracked so I was wondering would a cylinder head from a 1999 Volvo XC70 fit or can someone give me a list of Interchangeable models? thanks
Has thanked: 1610 times
Been thanked: 4065 times
I think from a 1999- you need to match the head with the same kind of variable valve timing, either intake, exhaust, or both, and the same displacement.
But, let the experts here chime in.
Has thanked: 2200 times
Been thanked: 1852 times
There is no such thing as a 99 XC70. That numbering system came out in 2003? Up until then they were V70 XC, even the first 2 years of the P2 models.
If you are taking the info off a website that is not a Volvo specialist parts supplier chances are they have it wrong. Contact them and you will find it SHOULD be the same as yours. Provisos as per the comments from abscate on checking the position of the VVT cam.
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
So you should have Exhaust only VVT, B5254T motor. VIN from donor car should be YV1**56**X*******
Sources would be 1999 C70 LPT cars, S70 GLT or AWD sedans, V70 GLT, AWD, or XC wagons.
Current Volvos:
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
duckman68 wrote: 27 Jan 2018, 20:59 I have a 1999 Volvo v70x/c 2.4l turbo the cylinder head is cracked so I was wondering would a cylinder head from a 1999 Volvo XC70 fit or can someone give me a list of Interchangeable models? thanks
If the cylinder head got hot enough to crack, I would replace the entire engine. Just my 2 cents.
duckman68
Post by duckman68 »
thanks everyone
