Can't make any more entries in the poll... is it broken or turned off?
I think this is very interesting and useful. Not the total number of repairs so much as the ratio of the different types of repairs. Very telling are only a few ETM repairs. I think this shows how problems can get blown out of proportion on forums just because they are discussed a lot. For example, reading the forum one would get the impression from the comments that all the ETMs are failing, but that isn't borne out by the data posted here. Again, a very useful poll.
List your 850/S70/V70/XC70 parts failures, 1992-2000 only
C@lvin
- Year and Model:
- Been thanked: 2 times
I listed the failures for my 98 S70 203K only and did not list them for my 00 V70 120K. I didn't think to list all the failures for both cars but, in fact, the ETM did fail on my 00 V70.instarx wrote:reading the forum one would get the impression from the comments that all the ETMs are failing, but that isn't borne out by the data posted here
Calvin
98 S70
00 V70
240,245,760,940,850 Turbo
98 S70
00 V70
rw_stebbins
- Year and Model: 850 1995
Also failed: Interior Fan & Resistor, Radiator now Leaking. 1995 850, 126K miles.
'99 s70 AWD- 136k miles:
ABS/traction module (an excellent repair available for $157.00!!)
Radiator (not damaged-leaked for no reason at seam)
antenna mast (cheapest fix @ $19.00)
CPS
Coil (just one)
heater core(just a little leak-haven't replaced yet)
passenger door lock (looks locked but isn't)
power mirror button (works with a little finagling)
driver side visor (fixed with a small bungee-saved $275.00)
rear speakers(replaced with better aftermarket brand)
Thermostat
oil cap gasket
CPS
Coil (just one)
Thermostat
oil cap gasket
patchesohoulihan
- Year and Model: S70 Base 98
Huh. Must suck to be you guys, just:
Ball Joint
Key Ingnition System.
With 115k. VOLVOS RULE!!!!! Lets see a honda be that good, beotches.
Ball Joint
"Just because you get a brilliant idea doesn't mean you won't do something painfully stupid with it"
Well here goes.
1998 Volvo V70/XC. Bought for $2000.
Replaced as soon as I got it.
Driveshaft
Right and Left Axles
Cat Converter
Both rear mufflers
Engine and Transmission mounts (replaced with OEM)
Now I have a bearing noise in the transfer case(?) and a slight drive shaft wobble when starting out. If anyone has any input on what the driveshaft wobble or bearing(ish) noise is I would love to hear from you ([email protected]!) Replace the ! with a t)
Driveshaft
Cat Converter
Both rear mufflers
thegeeknme
- Year and Model: 1998
- Has thanked: 2 times
98 v70, purchased 11/10 with 167k
I think I've already voted for HEATER CORE, STRUTS, SWAY BAR LINKS, FUEL PUMP RELAY... but I couldn't find the post.
In last 5months... add to the list WINDOW SWITCH, THERMOSTAT, RADIO DISPLAY LIGHTS, REAR HATCH STRUTS, KEY FOB HOUSING
fwiw...
Just came back from a trip over the mountains to play in the snow... man what a great car to drive! Love it!
fwiw...
ABS MODULE (Resoldering did not help) Bought used one on FleaBay $60.00
1996 850 Turbo Sedan
2002 VW Passat 4-Motion (wife's wheels)
1984 F-150 4wd.
Previous interesting vehicles:
1974 Ferrari Dino 246 Spyder
1973 Bentley S Sedan
1956 Jaguar XK140 Roadster
1929 Salmson (first production DOHC engine)
1926 Darracq Tourer
1984 F-150 4wd.
1926 Darracq Tourer
- 1618 Views
Last post by foggydogg
- 36 Replies
- 7982 Views
Last post by bmdubya1198
- 18 Replies
- 8762 Views
Last post by rspi
- 1377 Views
Last post by clarkerussell
- 23 Replies
- 6333 Views
Last post by oragex
