Generic P80 AC clutch shim , bread clip, zip tie thread
This topic is in the MVS Volvo Repair Database » AC Shim Fix: Are Zip Ties the New Bread Clips?
patcal
Year and Model: 1998 S70 GLT
Has thanked: 99 times
Been thanked: 10 times
Post by patcal »
My clutch on my 2004 S60 cycles on & off every 20-30 seconds. Can't seem to get 134r into it. Checked my gap was at .635mm. Way over. I'm going to try zip ties tomorrow.
Pat Callaghan Jr.
98 S70 GLT
crasbe
Year and Model: 02 S60, 98 V70 (EV)
Has thanked: 33 times
Been thanked: 82 times
Post by crasbe »
I learned about this fix after having the refrigerant replaced in my 2002 Volvo S60 and the error that the compressor only cycled for a few times remained.
The P2 platform unfortunately has very little space to access the compressor and it seems like clutch is made a little bit different. One way or another, I couldn't even get in a zip tie behind the flower-shaped sping.
So I cut up a metal stap which had the right thickness and bent a small L-bracket out of it to slide behind the spring. That bracket then got bent up so it won't fall out and the gap was pretty much perfect at around 0.4mm.
In total I added three of the brackets and the gap was very consistent, so I didn't bother putting another three in.
Maybe that helps someone who struggles with zip ties when the gap isn't big enough :)
Check out my 3D Printed Parts for Volvo P2 and P80 on Printables :D
rolsen11
Year and Model: 00 V70, 04 S60R
Has thanked: 57 times
Been thanked: 58 times
Post by rolsen11 »
Nice! That should work well for you. Thankfully I was able to stuff a few zip ties in mine a few weeks ago, though I cracked the screen on my phone in the process ): (it fell out of my hand and landed on a tiiiiny rock)
2000 V70 SE - Bought sight unseen in Cleveland, no longer my only car. Looks identical to my profile picture
2004 S60 R - M66 "Spaceball" manual transmission, Atacama "orange" interior, Titanium Gray metallic
Has thanked: 1613 times
Been thanked: 4075 times
I’m reporting this case of Oetiker desecration to the appropriate authorities.
crasbe
Post by crasbe »
abscate wrote: 16 Aug 2025, 03:53 I’m reporting this case of Oetiker desecration to the appropriate authorities.
If you only knew that that clamp was from a VW Bug axle boot kit too :twisted: :lol:
Not even a Volvo part.
