1998 V70NAM56 (NOW ENGINE SWAP) , winter 2020 "The Orange Mountain"
callahanoffroad
Year and Model: 1995 850
Has thanked: 16 times
Been thanked: 53 times
Post by callahanoffroad »
Glad you had to do this before me! I'll let you figure out how not to do it and then glean that info for my own benefit! Thanks Abscate!
Author, Chef, and Shade Tree Mechanic
1995 Volvo 850, Non-Turbo, VVIS, LH FI, Green, 215,000 miles. B5254FS engine. Herman. viewtopic.php?f=1&t=84393
1996 Volvo 850, died at 280,000
Founder of: CookingForChemo.Org
Read my Silly Comic Book at: therealpizzabros.com/
Has thanked: 1611 times
Been thanked: 4072 times
UPdate
Sourcing new engine - can you guys help me Swag this out?
Engine out -(head already off, disconnects done ???HOURS
Engine rework ????? HOURS
Swap water pump, timing gear
PCV evaluate swap
Engine replacement ???HOURS
Ive got a lead on a $650 engine with good history local.
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
When I was contemplating the same procedure I was told pretty universally that the head re-work was 15 hours labor and the engine swap was 18. I can't imagine that has changed.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Has thanked: 2209 times
Been thanked: 1852 times
Dealer charges 10 hours for rear main seal replacement so Evan's estimate is good if you do little else other than out with old and in with new. Based on the time, if you have to do this then if you have a lead on a known good running engine with history that is a good start. question, would you do all that work without a timing belt, rear main, trans inner seal?
Neil
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
You can have the good running '98 NA engine sitting in my garage for cheap... only has 270k miles. Runs like a top!
Only problem is the location...
As far as hours for an engine swap, including a basic PCV and timing belt job on a '98 NA, I would say 12-14 hours if you're really working hard. My cousin and I pulled the aforementioned engine in about 3 hours, and it probably took me about 4 hours of work (or less) to get the engine into my S70 and running after doing the refresh work (oil pan seals, PCV, timing belt, cam/crank seals, cam cover reseal, etc.), which probably took another 5-6 hours. I was able to pull the old engine from my S70 pretty quickly since it was the same situation here, I pulled the head anticipating redoing the head, but heavy corrosion on the cylinder walls made the ultimate decision for me.
