Rear Brake Shims
Ironbutt1345
Post by Ironbutt1345 »
Are the rear brake shims available from auto parts stores or only from Volvo? My rear brakes squeal, and the brakes were replaced right before I bought the car. I bought some of the "goop" you put on the pads, and it helped a little but not much.
T.J., 1997 850 GLT
White850Turbo
Post by White850Turbo »
You may be able to get Autozone to special order something like that, but I would highly recommend going with the OEM Volvo shims. They're around $5 each even at the dealer. The part number you'll want is 1359772. Make sure upon reassembly that you use plenty of the anti-squeal grease all over the backing plate also.
-Sean
1998 S70 T5 (Almost Stock)
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
How to replace Volvo brake shims
As found in the MVS Volvo Repair Database :).
Also -> Amazon link
Ironbutt1345
Thanks, I'll try that.
T.J., 1997 850 GLT
Jot
Year and Model: C30 2010
Post by Jot »
Remember the arrow on the shim points up
