my 96 850 won't even turnover
red_baron
- Year and Model: 850 SW GLT, 1996
1996 Auto 850GLT SW NA w/255K+. Always fired right up at the turn of the key. Today came out of a store, hopped in the car turned the key, almost started, tried again nothing, then a puff of smoke came out from under front of hood. AAA came out, battery is ok, starter getting voltage, no flashing or illuminated dash warning lamps. Towed home. Now the fun begins. Bad starter/solenoid??? Suggestions?
__________________
The Red Baron- a '96 850 GLT SW Auto NA (K&N filter, Bosch Iridiums) 248K +miles
Previous
1967 122S
Previous
1967 122S
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
The puff of smoke isn't good, but says that it's something electrical.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
kendpotter
- Year and Model: 1993 850 GLT Sedan
Pull codes.
red_baron
No burnt wires that I can see. No noise from the starter/solenoid at all. No clicking, no attempt to turn-over the engine at all. Connected my code reader: no codes reported.FCPGroton wrote:Definitely sounds electrical. Are there any burnt wires around the starter area? Will the car turn over freely but just not start?
__________________
Previous
1967 122S
Previous
1967 122S
red_baron
Followed diags in Haynes manual re: STARTER/SOLENOID. As a result , determined starter was toast. Pulled starter out of my donor 96 850 (PITA) and installed (PITA). Started right up. On inspection of the "bad" starter the grounding cable from the solenoid to the starter had rusted thru, maybe shorting out and blowing the solenoid. Back on the road 255K+ miles and counting!
__________________
Previous
1967 122S
Previous
1967 122S
- 995 Views
Last post by brent72
- 799 Views
Last post by shevolvo45
- 1334 Views
Last post by Ethan Rode
- 11 Replies
- 2290 Views
Last post by ashlee2319
- 15 Replies
- 606 Views
Last post by jonesg
