squeaking rear brakes Topic is solved
cohophysh
Just replaced the rear brakes on 850. installed shims and applied anit squeak, well they squeak like crazy. should I apply more antisqueak? replace the shims with new shims (pads didn't come with shims, i used the old ones)? Any suggestions
yeagermeister
- Year and Model:
did you just replace pads or did you replace the rotors as well?
(the other) sean
'94 855 5-speed
'02 lifted Nissan XTERRA
'94 855 5-speed
yeagermeister
- Year and Model:
sometimes new pads on old rotors will squeal until the pads wear enough to take on the groove profile of the rotors.
Jot? your take on the brand/composition? autozone typically runs the Wearever Gold as a standard.
(the other) sean
'94 855 5-speed
'94 855 5-speed
Ironbutt1345
- Year and Model:
cohopsysh, you GOTTA replace the shims with new ones. I just did the rear brakes on my 97 850 GLT, and at first I didn;t even use shims, just the anti squeak goop, but it didn't matter. I went to my local Volvo dealer and got the shims for $16 plus tax, put them on with some anti squeak goop, and it hasn't squeaked since. My wife now drives the car since it doesn't sound like a garbage truck any more!
Hope this helps you!
T.J., 1997 850 GLT
- 1428 Views
Last post by T5S60
- 1946 Views
Last post by Miltown
- 3080 Views
Last post by CheapAssGus
- 980 Views
Last post by ItWasTheSalmonMoose
- 5797 Views
Last post by vtl
