Good night you all !!!
Does any of you know how to test these parts:
1- 1997 Volvo 850 Base Air Pump. I got an used in mint condition-exterior- but not tested
2-1997 Volvo 850 Base Air Pump Relay. It comes with the pump but the seller does not know how to test them but said to be working. I prefer " trust but verify" .
Thanks in advance for your help.
1997 Volvo 850 Base Air Pump and Air Pump Relay to be tested
- osman
- Year and Model: 2002 c70 hardtop
bench test with 12v/
on the relay the largest prong is the pos and the center prong is the ground
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
99 XC70 AWD LPT 115
sothernmech
- Year and Model: 850 GLT 1995
Thank you osman for you help.
sothernmech
sothernmech
- osman
Usually i find that both the fan and or the relay are working and for one reason or another its just not turning on.
Its only supposed to turn on during cold starts and even then only for a minute or two.
Brick Life
99 XC70 AWD LPT 115
99 XC70 AWD LPT 115
- osman
Brick Life
99 XC70 AWD LPT 115
99 XC70 AWD LPT 115
- Has thanked: 311 times
- Been thanked: 817 times
Easiest way to solve this is to do the SAS delete.
Some people like to keep their car stock and I can appreciate that. But SAS is an emissions control system that was used briefly on these cars, then abandoned. You are not hurting the car or the outside or anything else by eliminating it. A $2 diode, a wire connector or some solder and 20 minutes of your time, and you are done with it forever.
http://volvospeed.com/install_performan ... -pump.html
- 2159 Views
Last post by precopster
- 1002 Views
Last post by xHeart
- 11 Replies
- 2735 Views
- 1765 Views
Last post by erikv11
- 2145 Views
Last post by SonicAdventure
