Flashing check engine
beasty918
Year and Model: 2001
Post by beasty918 »
I just changed a coil pack my car was running fine after that now my check engine light is flashing and I have a slight vibration in the car and when I accelerate she have no power at all...
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
The flashing CEL indicates a misfire which also matches your symptoms. Usually it is ignition but it could also be indicative of a burnt valve. Read the codes to see which cylinder is misfiring and then try swapping the coil for that cylinder with another cylinder and see if the misfire code moves along with the coil or if it stays with the cylinder.
