need help with 2003 xc90 t6
joedesu1
Year and Model: 2003 xc90 t6
Post by joedesu1 »
Hello all,
New to Volvo's and just bought a used xc90 t6 for our family. Was running fine and was doing some basic repairs such as fuel filter, air filter, oil change ext and got some codes regarding the engine running rich. Codes came up 2178, 2180, 2190. Then the other night the car stalled and was running erratically and wouldn't move. I got out, unplugged the MAF sensor and boom it ran. So I went online and bought the correct brand new MAF sensor which was OE Bosch and was not a remanufactured unit. Got the sensor today and installed it and still get erratic rpm and idle then the car dies. Unplug the sensor and the car runs fine. Could it be a defective sensor? What are other areas I should look into? Thank you for any input you may have.
Joe
joedesu1
Post by joedesu1 »
No one has any suggestions?
Roger_850T
Year and Model: 854T 1995
Been thanked: 26 times
Post by Roger_850T »
So those codes seem to be:
P2178: Long Term Fuel Trim Upper Limit
P2180: Long Term Fuel Trim, Bank 2 - Upper Limit
P2190: Long Term Fuel Trim, Bank 2 - Lower Limit
If you enter the codes into the search bar at the top, you can find a couple of threads dealing with this:
https://www.matthewsvolvosite.com/forums ... hp?t=20811
https://www.matthewsvolvosite.com/forums/vie ... hp?t=53133
I have usually found long term fuel trim to mean it's time to replace the oxygen sensor. Their response gets slow over time, and when they don't respond fast enough it sets a code. But see what others have run into before jumping into replacing parts.
Roger
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
Roger_850T
Looking around, this can also be caused by intake air leaks, especially at idle. Maybe give it a good inspection and see if there are any leaks, holes, failed vacuum elbows, etc.
Also, thinking about it, the O2 sensors would set the code, but not cause the other driveability issues you mentioned, so I tend to suspect them less in your case.
Roger
11 XC60 137k
05 XC90 V8 213k
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
I would try another MAF It would not be the first time someone got a bad new electronic part. Also, check the vacuum lines to the turbo controls, the sensor on the brake booster line etc.'s one on the lower side of the over the engine ducting, and one at the LH side of the intake manifold that are easy to miss
Current Volvos:
