'96 850 Tailgate Lock Issue
Tinwood
Year and Model: 1996 850 GLT
Post by Tinwood »
It seems that my tailgate locking/latch mechanism has failed. I cannot get the tailgate unlocked/open using either the fob or the dash unlock button. Tried the outside latch handle but it won't work. Even tried using the inside handle and still can't get the tailgate open. Any ideas as to how to, first, get the tailgate open and secondly, get the mechanism to open/close/lock/unlock again? I can hear the solenoid working but nothing happens when trying to use the inside or outside latch. I suspect that the release mechanism has somehow come apart but I can't get the tailgate open to get to the inner door mechanism to see what the problem is.
Has thanked: 1609 times
Been thanked: 4063 times
You will have to remove the rear trim to get access to the release.
See thread below on the mechanism
viewtopic.php?f=1&t=84018
Tinwood
Post by Tinwood »
Thanks for the info. Do I assume that for my '96 that the mechanism is a non-two stage lock? Is the info shown in the referenced thread for the two stage lock the same for my vehicle? What is the proper procedure for removing the rear trim (not having attempted this before)?
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
You don’t need to remove any trim, you would break it if you had to.
Crawl back there and use a large torx, I think it is t50, to unscrew the latch from the floor of the cargo area. Two bolts. Then open the gate and deal with it from there.
Post by erikv11 »
Oh and both of my 96 wagons were/are two stage locks.
Tinwood
Post by Tinwood »
Thanks erikv11.
DeadEric
Year and Model: 1996 850 Turbo
Has thanked: 2 times
Been thanked: 12 times
Post by DeadEric »
Make sure the handle on the outside isn't stuck pulled toward you (opening) position. I've had it where you squeeze it to open and it doesn't spring back. Being stuck in that position can interfere with the lock.
Tinwood
Post by Tinwood »
Thanks for that tip DeadEric.
