List your 850/S70/V70/XC70 parts failures, 1992-2000 only
Locked
What's *failed* in your 850, S70, V70, XC70, C70 (1992-2000)
Timing belt
50
2%
Top engine mount bushing
262
10%
Thermostat
152
6%
Door check strap or hinge
183
7%
ABS module
285
11%
Rear main seal
62
2%
Wheel bearing
92
4%
AC evaporator
103
4%
ETM
46
2%
Battery cable
48
2%
Any keyless entry component
129
5%
Any interior switch
210
8%
Camshaft position sensor
48
2%
Fuel pump or relay
111
4%
Heater core/ blower / resistor
183
7%
AWD's driveshaft or bevel gear
43
2%
Power antenna
156
6%
Sway bar links
146
6%
Mass airflow sensor
126
5%
Air pump
67
3%
Glovebox lock
65
3%
Head gasket
32
1%
Total votes: 2599
igel513
Year and Model: 2003 S60 T5
Post by igel513 »
98 S70 NA w/ 194k miles - items replaced:
all motor mounts
SAS valve
Heater core
Sway bar links
Front brake hoses
CV axle - torn boot
Radio due to unavailable code and no CD player
rear shock absorbers
front struts
c900s
Year and Model: 1999 V70XC
Post by c900s »
1999 V70XC that I have owned since 02/2006. I purchased it with 78K on the odometer and I am now at 107K. Reading the forums, I feel lucky (so far) in the repairs that needed to be addressed. There, of course, have been maintenance costs. However, I have noticed oil consumption rising along with a just noticed cloud of smoke when on a long trailing throttle down a hill and then back on the throttle. But it has been a great car!
Thermostat
Center Bearing on Driveshaft
Upper Front Strut Bearings
Allen in Hemet
Year and Model: 2000 V70XC SE
Post by Allen in Hemet »
2000 Volvo V70XC SE
Items that I have replaced since the time I bought the car almost a year ago (11/09):
All five ignition coils, rear seal on angle gear, turbo oil return seal, B+ cable. Items, All little litebulbs inside radio, and some rocker switches on dash.
Items I have repaired that did not need replacing: R/R window swich, tail gate innerpanel was loose, not anymore.
Items previous owner replaced (Thank goodness for good service record keeping, and for him, an extended warranty coverage):
ETM (now wears a yellow sticker), heater core, 2 radiators, expansion tank, A/C evaporator, front struts upper mounts, Angle Gear replacement ($1,900 at Berkly, CA dealer), ABS module, Tailgate innerpanel repair kit, front shifter console and 12V power port.
dandistefano
Year and Model: XC 1998
Post by dandistefano »
1998 XC AWD V70
ABS Module
Drive shaft bushing
2 front table links
1 rear table link or sway bar
Turbo back line leaking
Drive shaft
brake lines front/back
MAF
martynj
Year and Model: 00 V70 SE
Has thanked: 2 times
Post by martynj »
Can we add to the list:
Turbo oil cooler lines
radio illumination bulbs
shift lever microswitch
Center armrest cupholders
80 242 - on the way to a new home
93 245 - T-Boned (still miss it)
98 S70 GLT - scrapped
00 V70 SE
04 V70 2.5T Ti
04 S60RM Black Sapphire on Gobi
linkhart
Year and Model: 855 GL NA Man '96
Post by linkhart »
ABS module
pcv system
DavidLearner
Year and Model: 1996 850 Turbo
Post by DavidLearner »
New member here. Was surprised to see no mention of the PNP switch failure. Had to replace this on both my 1994 and 1996 850 Turbo wagons. Just did the '96 this week at 153,000 miles.
David Learner
'96 850 Turbo Wagon
Previously Owned Volvos
1993 245 Wagon
1994 850 Turbo Wagon
264 Sedan
164 Sedan (2)
MNCO1
Year and Model: 850 T-5 1997
Post by MNCO1 »
There is no way to make an entry onto the survey, so I'll just mention that my fuel pump crapped out.
Colonialgirl
Year and Model: S-70, 1998
Post by Colonialgirl »
I've lost both upper strut bearings, a thermostat, and the part that goes from the end of the power steering ram over to the right wheel. I replaced both front wheel struts when I replaced the upper bearings.
outrigger777
Year and Model: 2006 xc90 1998 v70xc
Post by outrigger777 »
Have owned a 1994 850 wagon, which I drove from a 103,000 to 210,000 miles. Only problem was that the power window control panel on the center consol had to be replaced--$1000. That was it. Now own a 1998 v70 xc with 105,000 miles, that I just bought 2 months ago. It's in mint condition and the owner had maintenance records showing a trip to the volvo dealership every 5,000 miles. Had to replace a broken engine mount, and replace the rear struts on the back hatch. (I knew they were broken when I bought it.)
One thing I've noticed on this thread is that no one has said anything about transmissions-- with the exception of some clunky shifting. Is this a good sign?
Locked
