1998 V70 Cambelt change with hydraulic tensioner
frontrow
Year and Model: Volvo V70 AWD
Post by frontrow »
Hi folks
There's such a mish mash of info re which models have mechanical or hydraulic timing belt tensioners so I just grubbed in and pulled my cover to check what my wagon has..... and indeed I do have a hydraulic tensioner on my Australian delivered V70 AWD (build date of 7/97).
Funnily enough my workshop manual purports to cover models from 1996 - 2000 however doesn't even mention a hydraulic tensioner!???
I'm sure the procedure for doing the cambelt change has been discussed before however I haven't been able to track it down by searching. Could I trouble someone to please point me in the right direction re this job?
Cheers in advance
vjaneczko
Year and Model: 2006 S60R
Been thanked: 6 times
Post by vjaneczko »
Over here we call them timing belts :)
This is one of the best write-ups on the subject:
https://www.matthewsvolvosite.com/forums ... =1&t=19831
It features a turbo engine so some of the parts may differ, but the steps should be the same.
Take a peek at this page and you'll see plenty of other help:
https://www.matthewsvolvosite.com/forums ... =1&t=47793
1997 855 GLT - R.I.P.
2006 S60R - For ME!
Has thanked: 292 times
Been thanked: 765 times
This is a classic link for timing belt DIY, been up for like 8 years, simple, well illustrated and crystal clear:
http://volvospeed.com/volvo_repairs_how ... hange.html
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
It's the same as the 850. Turbo or not it's the same. Easy to follow.
As for the tensioner, compress it with a clamp very slowly, maybe 1/2 turn every 5 minutes. If it leaks any fluid, change it.
frontrow
Post by frontrow »
That's terrific folks. Thanks VERY much indeed. Ah yes.... 'timing belts' it'll be from now on.
cheers!
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
If you need a hand the first time around, and you're in my area (Northern suburbs) more than happy to lend a hand with your cambe...I mean timing belt. We can exchange some ideas about the maintenance of these beasts and share a common interest. PM me if that appeals.
frontrow
Post by frontrow »
awesome, pm sent
