Loosen that clamp - you found out how to do that hard part.xHeart wrote:I was able to loosen the 7mm clamp screws at the each end of charged-air hose. But could not figure out putting it back together once taken off, so left it for another weekend.cn90 wrote:I have the exact same leak, no oil on driveway though.
I just cleaned it and will keep an eye on it.
PS:
- PCV just overhauled in Dec 2012.
- Spark Plug Plastic Cover removed, so top of engine is clean.
Anyone out there with notes on removing and installing charged-air hose?
Disconnect the PTC connections.
PULL - hard!!!
