any way to disable the factory alarm ?
Jetjky
Year and Model: 1998 S70 GLT
Post by Jetjky »
I can not find that relay anywhere. I took the panel off, got under there and encountered the "iron dome" with the SRS warning sticker. Pulled four relays to check but none of them were the 210/211 relays. Mine is a 1998 S70 GLT. I just want to disable the alarm system entirely. My lone objective is just to be able to start the car, drive it, and lock the doors. Key fob has been broken for years, no desire to repair it or replace it.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
What srs sticker?
You should sneak under steering wheel. :!:
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Jetjky wrote:I can not find that relay anywhere. I took the panel off, got under there and encountered the "iron dome" with the SRS warning sticker. Pulled four relays to check but none of them were the 210/211 relays. Mine is a 1998 S70 GLT. I just want to disable the alarm system entirely. My lone objective is just to be able to start the car, drive it, and lock the doors. Key fob has been broken for years, no desire to repair it or replace it.
You won't find the 210/211 relays on a 70 series because they aren't there. They only live on the 850s and the '98 S70 has a different system that is considerably more complex. The '98 is not as complex and the '99/'00 version but it was getting there. Back at the original post the car was never identified and it was assumed that it was an 850 which may or may not have been correct.
Jetjky
Post by Jetjky »
Thanks. Yes, it is a 98 S70 glt as I mentioned in my earlier post. I gave up today. Got the remote to work the door locks and alarm function but the alarm flashers still will not turn off. I pulled the battery to recharge overnight. Looks like I am going to have it towed in tomorrow.
It did this once before this week but unlocking the door and cycling the lock a few times with the key fixed it. Not this time.
Jetjky
Post by Jetjky »
misha wrote:What srs sticker?
Supplemental restraint system. There is an impenetrable steel shield under that facia panel.
Post by Ozark Lee »
Jetjky wrote: Supplemental restraint system. There is an impenetrable steel shield under that facia panel.
That panel comes off by removing the nuts that are accessed through the holes on either end. It isn't part of the "Active" SRS system, it is just a knee bolster and there isn't anything wired to it.
nono7777
Year and Model: V70R AWD 2007
Post by nono7777 »
I have a C70 T5 from 98. Unfortunately I have only one fob and I made the mistake to forget it in my pocket, so it went inside the washing machine. The remote does not work anymore so I cannot disarm the alarm.
It seems that I need to go to the dealer with the car to program a new remote. So I need to start the car. Is there any way to bypass the alarm and start the car without the fob on a 98 C70 ?
I have a used remote from my previous 98 V70 with same id than the C70, I tried without success to program it like they said on some posts found in internet, but I guess it only works with 850.
thanks for your help.
BenzinBoy
Year and Model: 1998 s70
Post by BenzinBoy »
This is how I did it on the Volvo I had. The central locking stopped working for a while and finally the alarm started to go off every time the battery was connected. As neither of the door locks would disable it was clear it was the module.
The module is under the dash, drivers side above the kick panel. May need to remove the knee guard. A black box with 2 green connectors with numerous wires (may say ABS, on the backside). As this was bad it was no longer needed (Plus I don't think anyone would want to steal my Volvo) it was thrown away.
A cheap pushbutton was purchased from Napa that would allow the starter to turn. As the module would no longer be doing its job power would have to get to the starter relay a different way. The center pin in the relay is what needed power. So a fused power wire to the switch in the car, and another wire from the switch to the center pin on the relay ( pretty sure that is pin 87). This bypasses the module and allows cranking. Just put key to accessory position, push the button and she starts. All for about $10!
Attached are some pictures of my work. Hope this helps so someone else isn't spending time dorking around with this.
The relay in question
Picture of the fuze/relay box. Power is take from the box and run with a fuze to the switch.
The push button in the dash, looking factory.
Location of the module.
TerrDawg
Year and Model: 97' V90/98' S90
Has thanked: 7 times
Been thanked: 13 times
Post by TerrDawg »
I have a 96 960 wagon, I'm selling it, new buyer doesn't care if find don't work, doesn't care if the alarm works but, when I changed the left front door, the key only unlocks the drivers door, doesn't disable the alarm ... she does want this fixed...
I either need to know where the 210/211 relay is hidden and which wires to jumper OR how do I fix, adjust or reattach the central locking manipulator doo-hickey .. is it an adjustment or wire with micro switch
Please help
Thanks
07' XC 70 Black/Lowered 136k mi
98' S90 blue 245k mi
98' S90 white super clean ! 274k mi
michael3man
Year and Model: v70 1999
Post by michael3man »
My 98 s70 M56 turbo car would not start without jumping the starter relay. Kept messing around, new ignition switch but to no avail. Caught this post and simply wired the relay lug #85 to ground and BINGO everything is working again!
Many thanks to those that contribute......... It is ugly, fast, and sounds angry with the OBX exhaust and the BOV. I LOVE it as a daily!
Best part is my lovely wife thinks I am crazy but she doesn't get why an older man would even drive it.
