99 S70 na Intake Hose
cajunxchange
- Year and Model: 1999 S70
cajunxchange
I appreciate it. I was confused because I kept hearing that these models didn't have an aic. Do you know if I can attempt to clean it with MAF or throttle body cleaner before replacing it?
- Been thanked: 4071 times
If you have ETS, electronic throttle System, you don't have an IAC.
Is there an ETS light on your dash when you turn the key on, without starting ?
cajunxchange
Yes Ive removed the etm to clean it the other day. I googled the sensor on the intake hose which led me to the iac. The iac connects to the intake hose with iac hose connecting to the intake manifold. I ordered the hose yesterday. I will attempt to clean the valve once I have the replacement. The one currently installed is very old. Thanks for the input. I will give an update once i pull off the valve and sensor.
I don't think that is an IAC. Once you electronically control the throttle,there is no reason for IAC.
Ill look at my 1999 NA parts car and see if I can learn what this is.
Perplexed....
Perplexed....
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
http://www.volvopartswebstore.com/showA ... tring=idle air control
I pick n' pulled one of these a couple weeks ago for a friend w/ a 99 N/A.
Current Volvos:
cajunxchange
I appreciate the help!
cajunxchange
cajunxchange
http://parts.volvocarsofhuntington.com/ ... 70245.html
I finally found the hose that connects for anyone that's had problems.
- 833 Views
Last post by phils94850
- 1550 Views
Last post by ektrules
- 1408 Views
Last post by erikv11
- 1064 Views
Last post by Sommerfeldt
- 1930 Views
Last post by Goupil
