99 S70 na Intake Hose
cajunxchange
Year and Model: 1999 S70
Post by cajunxchange »
New owner of 99 S70. Id like to know the name of the sensor and the hose that connects to the intake manifold. The replacements Ive found for the air intake hose have the sensor connection but seems to be missing the one that goes to the IM
Darkfleet
Year and Model: V70 1999
Been thanked: 3 times
Post by Darkfleet »
The sensor is the idle air control valve on the 99. Not sure if that hose has a specific name - maybe others can chime in.
cajunxchange
I appreciate it. I was confused because I kept hearing that these models didn't have an aic. Do you know if I can attempt to clean it with MAF or throttle body cleaner before replacing it?
Has thanked: 1610 times
Been thanked: 4069 times
If you have ETS, electronic throttle System, you don't have an IAC.
Is there an ETS light on your dash when you turn the key on, without starting ?
cajunxchange
Yes Ive removed the etm to clean it the other day. I googled the sensor on the intake hose which led me to the iac. The iac connects to the intake hose with iac hose connecting to the intake manifold. I ordered the hose yesterday. I will attempt to clean the valve once I have the replacement. The one currently installed is very old. Thanks for the input. I will give an update once i pull off the valve and sensor.
I don't think that is an IAC. Once you electronically control the throttle,there is no reason for IAC.
Ill look at my 1999 NA parts car and see if I can learn what this is.
Perplexed....
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
http://www.volvopartswebstore.com/showA ... tring=idle air control
I pick n' pulled one of these a couple weeks ago for a friend w/ a 99 N/A.
Current Volvos:
cajunxchange
I appreciate the help!
cajunxchange
https://www.fcpeuro.com/products/volvo- ... AuEs8P8HAQ
This is the actual part. Thanks again
cajunxchange
http://parts.volvocarsofhuntington.com/ ... 70245.html
I finally found the hose that connects for anyone that's had problems.
