1997 v70 T5 Stutter at WOT on T5
Has thanked: 2210 times
Been thanked: 1852 times
Resetting the codes just means the ECU takes some time to check the readings before realising the issue is still there.
Fuel pressure is definitely needing checked to at least eliminating it from the issues.
Have you checked if any oil has leaked into the distributor cap? If the oil seal leaks into the base of the distributor it can cause chaos in the running of the engine.
Another simple thing to check is the routing of the cam sensor cable where it runs near the distributor. If it runs too close it can cause signal issues in the signal to the cam sensor.
Final thing is removing the ECU and check the connections for corrosion.
Fiodor
Year and Model: 1997 V70 2.0 T5 AWD
Has thanked: 13 times
Been thanked: 9 times
Post by Fiodor »
scot850 wrote: 28 Feb 2021, 11:00 Resetting the codes just means the ECU takes some time to check the readings before realising the issue is still there.
I'll check the distributor tomorrow.
The ECU connections are perfectly fine.
I'll try to get ahold of my mechanic in the upcoming week.
Would hooking up a bicycle pump to the fuel rail give me a good approximation of the fuel pressure or do I need to use a special tool ?
1997 V70 T5 2.0 AWD with welded angle gear at 240k km
1990 740 Break (dead)
wizechatmgr
Has thanked: 45 times
Been thanked: 129 times
Post by wizechatmgr »
Fiodor wrote: 19 Feb 2021, 02:40 Battery is brand new, Fulmen 640A and 64 Ah.
I haven't removed the piggyback thingy, once my tank's empty I'll switch to regular gas and remove the piggyback apparatus.
Any chance you can post some information on the piggyback thing you're using for E85?
2023 Lexus RZ450e -66k
Do you mean a bicycle pressure tester? A pump won't help you unless I am missing what you are trying to tell us.
A regular pressure gauge like a tire pressure gauge (one of those metal slider types) might give you a static pressure but not what is being seen when under WOT.
Fiodor
Post by Fiodor »
wizechatmgr wrote: 28 Feb 2021, 17:01
I bought this kind of thing on Aliexpress for 80 euros:
https://www.boitier-e85.com/en/product/ ... -starflex/
It basically multiplies the injector opening rate by a factor which you can set via a potentiometer in the box.
Has worked without issues for 3 years (appx 7000km).
In France a tank of gasoline costs roughly 100 euros and a tank of e85 costs 30 euros.
Fiodor
Post by Fiodor »
Some updates:
I replaced the intercooler with a do88 unit (glad I had a friend to help me!), didn't solve my issues ofc.
BUT ! I now have STFT and LTFT back for some odd reason.
I logged the voltage from my oxygen sensors and it seems a bit weird, could one of you educated people look at my curves ;)
The second one seems like it has a slight issue ?
Also, my exhaust is now popping on deceleration ?
Has thanked: 1611 times
Been thanked: 4075 times
I think your second OXS is high, should be closer to 0.5 V , but confirm that please
High voltage is a Rich fuel air ratio, too much fuel
The swing on the upstream sensor looks normal. That one gets dithered back and forth to close loop,on the injection volume
Fiodor
Post by Fiodor »
The plot thickens, had some trouble starting the car this morning and this afternoon, I filmed the afternoon start.
Car drove perfectly fine afterwards (with the stutter coming back after 8km).
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 277 times
Been thanked: 85 times
Post by hausmeister »
Fiodor wrote: 07 Mar 2021, 12:16 I logged the voltage from my oxygen sensors and it seems a bit weird, could one of you educated people look at my curves ;)
I wouldn't know what to make of these curves...
But you are saying popping exhaust, that I have experienced. Imo: Boost leak, vacuum leak, bad hose etc. At least that is what caused it for me. I guess the AFM senses still air flowing (escaping) which means it runs too rich and you get the popping... (?)
Would also explain why it runs like shit, and if you have a leak then sure, it won't have power.
(Or just a bad AFM)
Well, no way to know for sure, but if I have learned one thing during my 850 journey, it is that even if you think you have fixed all leaks there are probably more :lol:
Get a pressure testing kit, check the small Idle air controller hose... that is where I would start.
You said something about do88 rip kit? Which I also have. Check the hose clamp on the short hose directly on the turbo. I had trouble getting that one to stay on, and even when it was on it was leaking - which I only know because I replaced it with one of the heavy duty calmps and that fixed it (more power, no more backfarts).
850 T5-R '95 auto Image
Fiodor
Post by Fiodor »
I'll check that small hose once more :D
Idle valve hose has been replaced with do88 as well but I'll check the clamps too.
Bought a fuel manometer yesterday and I'm expecting it to arrive today, I'll update the post once I've gotten the fuel readings.
Should I measure the pressure at idle + revving or should I hook a long fuel hose into the cabin and check during real pulls ?
