06' V70 Front End Damage Repair
Has thanked: 1611 times
Been thanked: 4075 times
Looking great, and hope to see her back on the road soon,
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
thats coming together great.
will you paint it diy ?
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
jonesg wrote: 09 Oct 2023, 12:35 thats coming together great.
Thanks! I am thinking about it. But first I will get a couple of quotes from local body shops. If they are way out of the park I might try to paint myself. The timing for that won't be great as far as the weather in November, since I would have to do this outside.
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
Has thanked: 2210 times
Been thanked: 1852 times
Hopefully the quotes are not too crazy. Having painted a front bumper cover previously, I would gladly pay a pro to do it next time and so it can gets baked as well to harden the paint.
Amazing progress to date! Long (well not too long) may it continue to the end!
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Nice work, glad your daughter is okay. Paint Society has excellent videos on various repairs besides rattle can.
850 LPT
Post by 850 LPT »
It took almost exactly 2 months, but Greta is finally rolling again on her own. I took her for a 8 mile test drive last night and besides the expected "coolant low" message, there were no surprises. Not really knowing how strong the impact on the engine was, I was a little nervous about some hidden damage that might have occurred during the accident.
The car would have been done a week and a half ago, but the new Nissens radiator failed right away. The drain cock broke when I opened it to flush the system one more time. It's also a bad design because it only has flats, so you have to use pliers or something to open it. Which means the coolant starts running down your arm as soon as you open it. I did not like that at all and ordered a way more expensive OEM one. Of course no such issue with that. I also like that the OEM one has the metal sleeves in the pipes.
I got everything buttoned up on Monday morning, and then proceeded to polish the headlights in the afternoon. A few items still need to be addressed. The dip stick handle broke off during impact, and I can't get it out. I am also not able to pull the dip stick tube out. I can wiggle it around, but there seems to be a hard stop and it won't budge. Also, there are rubber trim pieces on the bottom corners of the windshield, which also cover the hinges. These broke into pieces when I removed them to install the new hinges. I have not even tried to find replacements for those.
Next is finding a body shop to paint the bumper, wish me luck.
Dirk
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Volvo/Mahle radiator is way to go. Install and forget. Also the most efficient ATF heat exchanger. I too installed Volvo radiator after having the factory one bent in an accident, no problem ever since.
jonesg
Post by jonesg »
the dipstick tube is held by a small bolt at the base, 10mm ?
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
Yes
2003 XC 70 (sold)
Blacklab467
Sorry, no bolt at the bottom, its at the top by the flange, and yes 10mm.
2003 XC 70 (sold)
