High beams not working. Topic is solved
- 02V70
- Year and Model: 2002 V70XC
- Has thanked: 53 times
- Been thanked: 40 times
Now with daylight savings, I am driving my 2002 v70xc in the dark more often. When I turn on the high beams, the indication light comes on, I hear a relay click, but the high beam lights do not come on. This has happened before, but intermittently. If I turned the high beams on and off a bunch of times, they would turn on properly. However, now they do not come on at all. What could be the problem? Is the relay bad?
2002 v70 X/C 288k miles
- Has thanked: 987 times
- Been thanked: 1076 times
Check wiring and connectors to the high beam bulbs. Check with voltmeter to see that power is getting to the bulbs. Check resistance across bulb for burnout of bulbs.
Both bulbs may have failed or wiring problem.
- firstv70volvo
- Year and Model: V70 T5 2001
- Has thanked: 52 times
- Been thanked: 123 times
Likely the high beam relay located on the CEM. You can swap it around with another relay to confirm. Since you can hear the relay click it's probably bad contacts within the relay.02V70 wrote: 10 Nov 2023, 22:35 Now with daylight savings, I am driving my 2002 v70xc in the dark more often. When I turn on the high beams, the indication light comes on, I hear a relay click, but the high beam lights do not come on. This has happened before, but intermittently. If I turned the high beams on and off a bunch of times, they would turn on properly. However, now they do not come on at all. What could be the problem? Is the relay bad?
Location of high beam relay (2/63).
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
.02V70 wrote: 11 Nov 2023, 15:25 The relay looked like this. I swapped it with the one for the fog lights, and now the high beams work!
You may have company!
- 885 Views
- 836 Views
Last post by ilcaa
- 717 Views
Last post by iamhives
- 1394 Views
Last post by chiefpontiac
- 1509 Views
