DIY: 1998 S70 GLT Documenting Vacuum Hoses [Turbo]
This topic is in the MVS Volvo Repair Database » Vacuum Lines on Turbo 1993-2000 850/S70/V70/XC70
shegarty
Year and Model: 1998
Has thanked: 12 times
Been thanked: 8 times
Re: DIY: 1998 S70 GLT Documenting Vacuum Hoses [Turbo]
Post by shegarty »
Any resources out there listing what size of hoses are required ... particularly for those lines related to EVAP? I am currently chasing the P0455 code :(
98 S70 T5 SE 298k km (daily)
87 740T sedan (current project)
previous - 90 745T; 94 855 T5
combatkarl
Year and Model: 1997 850 GLT
Post by combatkarl »
Another great post with photos. I found a quick fix to replace hose #1 from the intake manifold to the "fuel rail" tube. At the auto parts store, I found Item # 47092 Vacuum Elbow 1/4" from Dorman Help! products. Any O'Reilly or Advance Auto should have it. I tried a straight piece of vacuum hose, but was not happy with the results or kink in the hose. The attached photo has the the hose is highlighted - ignore the red arrow.
Intake Elbow.jpeg (132.2 KiB) Viewed 6205 times
Karl
1997 Volvo 850 GLT
2001 Honda Odyssey
1999 Mazda Miata
2012 Dodge Journey
1984 Honda Nighthawk S bike
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
combatkarl wrote:Another great post with photos. I found a quick fix to replace hose #1 from the intake manifold to the "fuel rail" tube. At the auto parts store, I found Item # 47092 Vacuum Elbow 1/4" from Dorman Help! products. Any O'Reilly or Advance Auto should have it. I tried a straight piece of vacuum hose, but was not happy with the results or kink in the hose. The attached photo has the the hose is highlighted - ignore the red arrow.
I replaced my hose as well, Volvo doesn't seem to carry it: I tried my dealer. I was able to carefully bend a stock piece of vacuum hose. No kink.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
shegarty
Post by shegarty »
mecheng wrote:I was able to carefully bend a stock piece of vacuum hose. No kink.
Same here, used braided fuel line which was what I could get my hands on and looped it around to avoid a kink on the tight radius - make sure to avoid leaving it too long or it will get caught in the fan :oops:
Has thanked: 292 times
Been thanked: 765 times
Silicone vac hose is great for keeping shape through bends.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
seb
Year and Model: 1997 Volvo 850 GLT
Post by seb »
I stripped the darn flared fitting with 22-mm nut by trying to take it of... I can find the check valve pipe on line, but I cannot find the flared fitting. Help !
Do you mean the SAS valve? If you have it off, consider getting rid of it altogether. It's one of the first things I do when I get a new P80 car.
http://volvospeed.com/vs_forum/topic/14 ... with-pics/
'06 S60 R, 197k
toatesarchitecture
Year and Model: 1998 V70 T
Post by toatesarchitecture »
I have a 98 V70 T project car - that started with no engine, and I put a 98/99 T engine in and need help with routing of vacuum lines. I may have extra pieces I dont know about, or missing T's and check valves. I've read every post and still am confused about what goes where. So I drew my own diagram - so if someone could connect the dots I'd be golden. I'm trying to attach it to this post, fingers crossed. John
Has thanked: 1505 times
Been thanked: 3818 times
This is the best, with the only ambiguous one being the blue turbo hose. That plugs into the nipple on the air box hose , down hear the turbo.
You might have some things to Klooge if it’s a 99 motor, specifically
Sas air injection, none on 99
Fuel pressure regulator ( none on 99, needed on 98)
Crankcase Pcv different
Turbo control valve different
Purge valve may be different
