No start after new battery 98 V70 glt Topic is solved
stephansvolvo
Year and Model: V70 GLT 1998
Has thanked: 21 times
Been thanked: 3 times
Post by stephansvolvo »
misha wrote: 20 May 2025, 00:48
stephansvolvo wrote: 17 May 2025, 19:26 ...I bought a new battery and as soon as I connect it I get the four way flashers and a no summary scenario.
It means that security/alarm system is triggered...armed and immobilised.
Use remote fob to deactivate it or a trick with locking and unlocking the doors with a key if you don't have a fob.
Also check battery cables and grounds.
Right. That is what I was thinking the immobilized. I don’t have a FOB for this vehicle. So any tips for this without a fob and key only?
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
98 S70 GLT
73 IH Scout ii
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Try to lock & unlock the doors 3 times from a driver's door lock.
If that doesn't reset alarm system,then you will have to bypass alarm relay.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
stephansvolvo
Got the alarm to reset via door locking unlocking. It tools about a dozen attempts, but it worked.
Vehicle started. Now to get the heater core replaced and the car cleaned up.
Thank you for your help on this.
Anyone know someone who can program a fob? Dealerships wants 150 for one fob! Crazy kids!!
Stephan
98 S70 GLT
73 IH Scout ii
misha
Post by misha »
You only need to buy a proper fob...good used one.
You can program it yourself.
I think that procedure is here somewhere on MVS.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Vova585
Has thanked: 228 times
Been thanked: 238 times
Post by Vova585 »
Round of applause to Misha for suggesting correct answer. Just for my education: i thought that immobilizer problem usually should be accompanied with a immobilizer(key) light on the dash. So older Volvo's dont have that light i guess and show the issue with flashing hazard lights?
misha
Post by misha »
Yes...but for cars with chipped keys.
U.S .market started in '99 while EU market cars had chipped keys from '96.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
stephansvolvo
Vova585 wrote: 22 May 2025, 14:44 Round of applause to Misha for suggesting correct answer. Just for my education: i thought that immobilizer problem usually should be accompanied with a immobilizer(key) light on the dash. So older Volvo's dont have that light i guess and show the issue with flashing hazard lights?
My vehicles have the red flasher on the dash.
Stephan
98 S70 GLT
73 IH Scout ii
stephansvolvo
misha wrote: 22 May 2025, 14:35 You only need to buy a proper fob...good used one.
I’ll search that up again. The last time I tried it I was told it had to be done at the dealership.
Stephan
98 S70 GLT
73 IH Scout ii
misha
Post by misha »
Yes...you're right...for all 70 series cars it's a dealer job.
If you have a good locksmith in your area...try with them.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Been thanked: 4065 times
There’s a lot of confusion on gobs/keys because EU!= NA market
For our side of Atlantic fobs are programmed:
-1997 fobs programmed by customer
1998 fobs at dealer with PIN OR WITH good reader
1999-on full blown Vida subscription with connection to Volvo server and car
