Are you kidding me? Look at the first video link I provided. The second video link which you mention was a method you may have to take to remove the bearing if it is seized. The first link is called "installing drive shaft bearing on 98 xc70 part 1". That is your question correct?
Yes I read your post and when I did I recalled the video I had seen in the past on the subject. The prop shaft is dismantled by a nut that is at the joint. It is in the first video I linked, not the second which you are jumping all over. Watch all of the parts of the guy's video on how to do your repair. The second video will provide additional information.
1998 V70XC Rear Propshaft "Hanger Bearing" Replacement?
- SuperHerman
- Been thanked: 207 times
- shiloh51933
- Has thanked: 28 times
- Been thanked: 17 times
I don't see any videos with a V70XC propshaft, I see a 240 and a bunch of other rwd videos. I did the searches and came up with all the same videos. If Google can't find exactly what your looking for it finds you the next closest thing. If you attached it I'm not seeing it. All those videos look like RWD to me, if it's there and I'm missing it can you attach just that one.SuperHerman wrote: 08 Apr 2018, 17:58 Are you kidding me? Look at the first video link I provided. The second video link which you mention was a method you may have to take to remove the bearing if it is seized. The first link is called "installing drive shaft bearing on 98 xc70 part 1". That is your question correct?
Btw when posting sometimes things read sarcastically. ..I tried to add that I wasn't being a wiseguy. I really appreciate your efforts.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
- SuperHerman
I don't have a 1998 XC70, but this video says it is about a 1998 XC70. Again it is in four parts.
- shiloh51933
Yeah i found this one on Google but unfortunately that's not the same propshaft I have. His title is wrong, it's a 1998 V70XC not an XC70, the XC70 is a P2 chassis not a P80 like mine. The XC70 came out in 2001 not 1998. That driveshaft has a slip joint, that's the splined joint that slips out of the shaft after you unhinged the U joint. TY for trying.SuperHerman wrote: 08 Apr 2018, 18:38
- SuperHerman
Post a few pictures of your problematic joint. I hear what your saying about the model year shift, but it cannot hurt.
- SuperHerman
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
I'd also be interested in a picture of this setup on yours. I have the '99 V70XC which will be slightly different.
2023 Lexus RZ450e -66k
- shiloh51933
Ok no problem, after work I'll post some pics. TY again for your efforts, I'll re all appreciate it. I had found a bunch of really good videos on hanger bearing replacement, like this guy "John Sadler" did a video on a RWD VOLVO 240. I mean I already know how to tear a RWD propshaft down and all then rebuild it but my '98 V70XC slip joint is welded in place and the few other '98-'00 propshaft are all welded, atleast what I've seen. I was thinking if I try to whack it apart I'll ruin the U joints or splines inside of what should have been a slip joint. Cutting with a hole saw might work but i dont own one.SuperHerman wrote: 08 Apr 2018, 19:00 Post a few pictures of your problematic joint. I hear what your saying about the model year shift, but it cannot hurt.
- SuperHerman
Post some pictures. From the last link I sent you it appears that the unit may have a circlip rather then a bolt. It may be buried in dirt and oil - hit it with some cleaner and a scrub brush.
- shiloh51933
Here's pic of my propshaft, see that weld....
If weld strip wasn't layed down I could pull u joint out of rear half of the propshaft and slide hanger bearing off with some work.
- 553 Views
Last post by VolvoOwl98
- 815 Views
- 580 Views
Last post by cn90
- 14 Replies
- 3202 Views
Last post by jvl
- 727 Views
Last post by SuperHerman
