MAP Sensor location Topic is solved
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
To do pictures click on Full editor (below) and use the picture functions.
You can attach the picture or link to one hosted on another website.
Active
Past
MALL240
Year and Model: 1991 240 2.3 turbo
Has thanked: 28 times
Post by MALL240 »
Maybe if we found de rubber tube that go connected to the manifold?? in your program? Can´t find it..
RickHaleParker
MALL240 wrote: 25 Feb 2020, 01:02 My engine is B230F
When I search with a B230F configuration, the part number does not come up. No engine pressure sensors come up for a B230F configuration. B230K configuration ... yes as shown above.
Active
Past
MALL240
Post by MALL240 »
OKKKKKKKK that's it. thanks a lot RIck!! I was going mad... i will return the piece... maybe my idle problem and hesitasion acceleration only in stopto run its from the regulator pressure ... its expensive, i will going to check if it clean and dry...
Thanks a lot guys!!!
RickHaleParker
MALL240 wrote: 25 Feb 2020, 01:19 Maybe if we found de rubber tube that go connected to the manifold?? in your program? Can´t find it..
Not that much detail.
B230F or B230FT (Turbo) ?
Active
Past
MALL240
Post by MALL240 »
B230F NO turbo
RickHaleParker
If you have a lot of kilometers on the car keep this in mind. A replacement fuel regulator does not need to last forever, it just needs to out last the car. You can get after market fuel regulators for about € 50.00 .
Active
Past
MALL240
Post by MALL240 »
Hi, yes.. i look in the rubber vacuum tube and its tottaly clean and dry... i believe its ok...
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
MALL240
Post by MALL240 »
Hi, thanks for answering. You mean the MAP is on top of the MAF, inside that piece? Does the MAP component come out on a B230F?
What a mess.
