98 S70 NA w/ 194k miles - items replaced:
all motor mounts
SAS valve
Heater core
Sway bar links
Front brake hoses
CV axle - torn boot
Radio due to unavailable code and no CD player
rear shock absorbers
front struts
List your 850/S70/V70/XC70 parts failures, 1992-2000 only
1999 V70XC that I have owned since 02/2006. I purchased it with 78K on the odometer and I am now at 107K. Reading the forums, I feel lucky (so far) in the repairs that needed to be addressed. There, of course, have been maintenance costs. However, I have noticed oil consumption rising along with a just noticed cloud of smoke when on a long trailing throttle down a hill and then back on the throttle. But it has been a great car!
Thermostat
Center Bearing on Driveshaft
Upper Front Strut Bearings
Thermostat
Allen in Hemet
- Year and Model: 2000 V70XC SE
2000 Volvo V70XC SE
Items that I have replaced since the time I bought the car almost a year ago (11/09):
All five ignition coils, rear seal on angle gear, turbo oil return seal, B+ cable. Items, All little litebulbs inside radio, and some rocker switches on dash.
Items I have repaired that did not need replacing: R/R window swich, tail gate innerpanel was loose, not anymore.
Items previous owner replaced (Thank goodness for good service record keeping, and for him, an extended warranty coverage):
ETM (now wears a yellow sticker), heater core, 2 radiators, expansion tank, A/C evaporator, front struts upper mounts, Angle Gear replacement ($1,900 at Berkly, CA dealer), ABS module, Tailgate innerpanel repair kit, front shifter console and 12V power port.
dandistefano
- Year and Model: XC 1998
1998 XC AWD V70
ABS Module
Drive shaft bushing
2 front table links
1 rear table link or sway bar
Turbo back line leaking
Drive shaft
brake lines front/back
MAF
ABS Module
Drive shaft bushing
2 front table links
Drive shaft
MAF
martynj
- Year and Model: 00 V70 SE
- Has thanked: 2 times
Can we add to the list:
Turbo oil cooler lines
radio illumination bulbs
shift lever microswitch
Center armrest cupholders
80 242 - on the way to a new home
93 245 - T-Boned (still miss it)
98 S70 GLT - scrapped
00 V70 SE
04 V70 2.5T Ti
04 S60RM Black Sapphire on Gobi
00 V70 SE
04 V70 2.5T Ti
DavidLearner
- Year and Model: 1996 850 Turbo
New member here. Was surprised to see no mention of the PNP switch failure. Had to replace this on both my 1994 and 1996 850 Turbo wagons. Just did the '96 this week at 153,000 miles.
David Learner
'96 850 Turbo Wagon
Previously Owned Volvos
1993 245 Wagon
1994 850 Turbo Wagon
264 Sedan
164 Sedan (2)
David Learner
'96 850 Turbo Wagon
1993 245 Wagon
264 Sedan
164 Sedan (2)
Colonialgirl
- Year and Model: S-70, 1998
I've lost both upper strut bearings, a thermostat, and the part that goes from the end of the power steering ram over to the right wheel. I replaced both front wheel struts when I replaced the upper bearings.
outrigger777
- Year and Model: 2006 xc90 1998 v70xc
Have owned a 1994 850 wagon, which I drove from a 103,000 to 210,000 miles. Only problem was that the power window control panel on the center consol had to be replaced--$1000. That was it. Now own a 1998 v70 xc with 105,000 miles, that I just bought 2 months ago. It's in mint condition and the owner had maintenance records showing a trip to the volvo dealership every 5,000 miles. Had to replace a broken engine mount, and replace the rear struts on the back hatch. (I knew they were broken when I bought it.)
One thing I've noticed on this thread is that no one has said anything about transmissions-- with the exception of some clunky shifting. Is this a good sign?
- 1605 Views
Last post by foggydogg
- 36 Replies
- 7961 Views
Last post by bmdubya1198
- 18 Replies
- 8629 Views
Last post by rspi
- 1373 Views
Last post by clarkerussell
- 23 Replies
- 6238 Views
Last post by oragex
