Am I screwed
- RickHaleParker
- Been thanked: 980 times
Compare the markings on both CEMs. It might be same software different data. As Precopster pointed out, you can read the software versions with VIDA.
Active
Past
Past
exzile9
- Year and Model: 2005
- Has thanked: 5 times
- Been thanked: 3 times
Precopster I'll check and see... Everything seems to work as far as Vida communication. There were some communication errors between modules BCM to CEM , CEM to ECU( that went away) the ECU doesn't show any errors anymore.
exzile9
The abs light goes away once the new CEM is installed, but start functionality goes with it lol.... I know any jacked up signals on the canbus can cause a no start... Has anyone seen doublebug our Yagger????
- Been thanked: 4071 times
Check for 12 Volts at each fuel injector. If that is present, you have an immobilizer fault
- 17 Replies
- 3513 Views
Last post by Gilly
- 36 Replies
- 10637 Views
Last post by MoVolvos
- 3079 Views
Last post by FormerFordGuy
- 255 Views
Last post by chitownV
- 3814 Views
Last post by newmex999
