Am I screwed
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
Compare the markings on both CEMs. It might be same software different data. As Precopster pointed out, you can read the software versions with VIDA.
Active
Past
exzile9
Year and Model: 2005
Has thanked: 5 times
Been thanked: 3 times
Post by exzile9 »
Precopster I'll check and see... Everything seems to work as far as Vida communication. There were some communication errors between modules BCM to CEM , CEM to ECU( that went away) the ECU doesn't show any errors anymore.
exzile9
Post by exzile9 »
exzile9
Post by exzile9 »
The abs light goes away once the new CEM is installed, but start functionality goes with it lol.... I know any jacked up signals on the canbus can cause a no start... Has anyone seen doublebug our Yagger???? πŸ€•
exzile9
Post by exzile9 »
@precopster yes the software versions show up...
exzile9
Post by exzile9 »
Bump for some help??
exzile9
Post by exzile9 »
exzile9
Post by exzile9 »
I have spark but no injector pulse...fuel Pressure is at 60 while turning over, but only cranks when starting fluid is sprayed in it...
Has thanked: 1610 times
Been thanked: 4068 times
Check for 12 Volts at each fuel injector. If that is present, you have an immobilizer fault
