For complete maintenance information, please refer to your
Warranty and Service Records Information Booklet.
R = Replace
I= Inspect (Correct or Replace if necessary)
L = Lubricate
| Maintenance Operation | thousand miles | 7.5 | 15 | 22.5 | 30 | 37.5 | 45 | 52.5 | 60 | 67.5 | 75 | 82.5 | 90 2 |
| (thousand km) | (12) | (24) | (36) | (48) | (60) | (72) | (84) | (96) | (108) | (120) | (132) | (144) | |
| EMISSION SYSTEM MAINTENANCE | |||||||||||||
| Engine oil and filter 1 | R | R | R | R | R | R | R | R | R | R | R | R | |
| Engine drive belt (accessory belt) | I | ||||||||||||
| Air cleaner filter | R | R | R | ||||||||||
| Spark plugs | R | R | R | ||||||||||
| Automatic transmission fluid | I | I | I | I | I | I | |||||||
| Timing belt – all engines3 | |||||||||||||
- See section “Engine oil” for detailed information.NOTE: The oil should be changed at these intervals, after 750 hours of driving or after 12 months, whichever occurs first.
- For services beyond 90,000 miles (144,000 km), please refer to the Warranty and Service Records Information Booklet”.
- For proper functioning of the vehicle and its emission control systems, the timing belt and tensioner must be replaced every 105,000 miles (168,000 km).
R = Replace
L = Lubricate
| Maintenance Operation | thousand miles | 7.5 | 15 | 22.5 | 30 | 37.5 | 45 | 52.5 | 60 | 67.5 | 75 | 82.5 | 90 |
| Engine | |||||||||||||
| Fuel line filter1 | |||||||||||||
| PCV nipple (orifice)/hoses, clean | I | I | |||||||||||
| Battery (check charge and electrolyte level) | I | I | I | I | I | I | I | I | I | I | I | I | |
| Brakes | |||||||||||||
| Inspect brake pads, replace components as necessary | I | I | I | I | I | I | I | I | I | I | I | ||
| Brake fluid level2 – check | I | I | I | I | I | I | |||||||
| Steering/suspension | |||||||||||||
| Tires3, check pressure, wear and condition | I | I | I | I | I | I | I | I | I | I | I | I | |
| Check power steering fluid level | I | I | I | I | I | I | |||||||
| Body | |||||||||||||
| Power antenna (clean) | L | L | L | L | L | L | |||||||
| Trunk/hood, hinges and latches | L | L | L | L | |||||||||
| Cabin air filter (see page 111 of the Owner’s manual) | R | R | R | R | R | R | |||||||
- Replace at 105,000 miles (168,000 km)
- Brake fluid should be changed at owner request every second year or 30,000 miles (48,000 km). The fluid should be replaced once a year or every 15,000 miles (24,000 km) when driving under extremely hard conditions (mountain driving, etc.).
- Rotate tires at owner request.
The following items should be checked weekly by the driver (it takes only a few minutes):
Engine oil level, brake fluid level, radiator coolant level, operation of all lights, horns, windshield wipers, tire pressure (all five tires), windshield washer fluid level
The following should also be carried out at regular intervals:
Washing (check all drain holes), polishing, cleaning
