940 and 960 cars from 1993 – 1995 can display fault codes for the Supplemental Restraint System using the On-Board Diagnostic unit in the engine compartment.
9 series (’93 – ’95) SRS diagnostics and testing.
Fentonmatt » I checked the codes on my 850 Turbo using the diagnostic box under the hood because my SRS light is on. I got the codes 2-3-1 and 2-3-2 which seem to be related to my seatbelt tensioners but they seem to be working fine. So, I’m trying to clear the codes by pressing the button on the A diagnostic box for 6-10 seconds then waiting for the light then holding again for same amount of time but code won’t clear. Is there something I’m doing wrong? Anyone familiar with this code and also since I have no other codes related to SRS is my airbag system still okay if I get in a wreck?? Thanks in advance!
Scott850 » Can’t answer the ‘is my SRS system ok’ as I can’t answer that without switching the SRS light off first. Not sure if you can switch SRS codes off with the diagnostic box in 92-95 cars that have them. I know in later models you need a special tool to switch SRS issues off or in 99- Vida can do it. You may have to take it to a dealer to do it assuming they still have the equipment. Does your car have the OBD2 connector below the ashtray in the center console? I think some 95’s may have had it. If it does, some aftermarket fault code tools may be able to switch SRS lights off. I know in later systems, if the light is on, it switches the system off until the issue is rectified. It may have come on by as simple a way as the system being on when the seats were worked on. So issue may be a false issue. Only way to find out is to switch the system off.
Last Updated on March 5, 2022
[…] a Volvo 940 or 960? Jump to the Volvo 940 and 960 SRS diagnostics. Same thing as this, but for those […]
Thank you for any other informative blog. The place else may just I get
that type of info written in such an ideal method?
I have a project that I’m simply now operating on, and I have been at the look out for such
info.
