Fast Friday #4 — The Boost Variance Problem
Boost pressure issues seem to be the #2 issue in the Volvo Performance world beaten out only by vacuum leaks. Boost pressure control in the 1994-1998 models is a pretty simple system but for the ECU to manage boost correctly it relies heavily on known base values and settings. If these settings are off or if there are mechanical issues then the boost control system can be out of whack.
Experiencing The Boost Variance Problem ?
Join us for our weekly Fast Friday discussions in the Volvo Performance Forum. They’re posted every Friday, with the purpose of providing understanding of not only how to add performance to your Volvo, but how Volvos work (stock) at a fundamental level. Topics include turbo boost, chips (tunes/ECU reflash), manual boost controllers (MBC), electronic boost controllers (EBC), tires & grip, performance suspension parts, and more.
You’re encouraged to join the Fast Friday discussion, either current or past, by either asking a question or adding your thoughts. If you’re not an MVS Forums member, please join the forum first, it’s free.
The primary adjustment is the wastegate setting. Factory setting of the wastegate actuator tended to not only be a quite a bit on the conservative side but also varied considerably. This inconsistency gets compounded when you are running a tuned ECU at higher than stock boost levels. For those running a manual boost controller (MBC) or an electronic boost controller (EBC) this might not be as much of an issue, however even with these aftermarket boost control devices the factory wastegate setting still required adjustment for them to work properly.
