This topic has 22 comments in the Volvo forum.
Recomended MBC for Volvo 850 Turbo
Manual Boost Controllers (MBCs) are the cheapest way to get more power out of your turbo. Please do a Stage 0 first!
clawless »
This link has a good ‘how to’ on boost controllers for Volvo turbos. With the ECU controlling the boost you may not get what you want with a MBC.
I plan on running his setup with Voodoo IV controllers once I get my other issues resolved, exhaust installed and upgrade the ECM.
matthew1 »
I’ve had a $80 Hallman ES MBC in my 850 T5 for months and it’s great. Yes, you can make one for $20. If I could do it over, I’d go that route. It’s just a dead-simple mechanical device that either works or doesn’t. You’ll know the second you accelerate from your driveway if you’ve gotten it terribly wrong. IF you have a boost gauge.
Installing a manual boost controller - diagram of hoses and routing
Installing a manual boost controller – diagram of hoses and routing
It boosts to 15psi in 2nd, 3rd, 4th gears, and up to 10psi in 1st. Stock T5 behavior is 10psi in any gear. I do not have an ECU remap/chip/tune. I do have an R ECU. I do not get fuel cutoff until ~90mph / full throttle.
I do have a boost gauge. I would feel very uneasy using an MBC without one.
