Volvo Oxygen Sensor Part #
I found a generic 4 wire sensor from Bosch at Auto Zone. Bosch #15717. Spliced it in, reset the check engine light and it fixed the problem…
You can now get the definitions of Global OBD II (P0) and Enhanced OBD II (P1) Diagnostic Trouble Codes (DTCs) online. Simply use the menus below to select your vehicle and request the definition of your OBD II DTC…
