Adjusting the Wastegate
Curious if your Volvo’s wastegate is properly configured? MVS Volvo Forums Contributor sleddriver documents adjusting the wastegate. He finds it off, and corrects it. Often owners “give them a few turns” to keep the turbo spinning in more situations, which reduces turbo lag when you floor it. This normally doesn’t cause damage because these Volvos are […]
Upgrade 850 Turbo to 18t Turbocharger?
Can I get a 18t turbo with a speed tunning chip and maybe some bigger injectors and be ok? Sure. Don’t do the 18t until you get a tune and do some exhaust upgrades, though. The tune is the important part – too much boost too low in the rev range, and you get bent […]
