I can’t find a single Volvo model of car or SUV that’s not on this list of recalls. I wanted to categorize this post, but it would literally be all categories, so I left it at “Volvo Car Company”.
Despite thorough testing and follow-up by Volvo, issues may arise linked to the construction or components of the car. At times, these might be minor, such as a software update handled during a routine service. However, on rare occasions, Volvo issues a recall, requesting owners to contact their local Volvo retailer to rectify a problem. This is especially pertinent when there are concerns that could potentially compromise safety, even in the absence of reported incidents.
Volvo Recall Information is accessible from August 1999-present. For recalls predating this, individuals should contact Volvo Customer Care using the Contact Us form or by calling 1-800-458-1552 for further details.
Stay up to date on your Volvo’s recall status by signing up for Volvo’s recall notice program.
See more detailed (but a narrower field) of Volvo recalls.
Examples of recall items
- BRAKE LIGHT RELAY
- BALL JOINT SEMS NUT
- INSPECT/REPLACE BRAKE VACUUM VALVE / HOSE ASM REPL ENGINE COMPARTMENT VACUUM LABEL
- FUEL TANK INSPECT / REPLACE
- REPLACE ELECTRIC COOLING FAN
- REPLACE HEADLAMP SWITCH
- Software Upgrade ECM (Poor Purge Performance)
- Battery B+ Cable
- Software Upgrade for ETM
- Replace Wiper Arms
- Tie Rods Replace – 2 Outer
- REPLACE FUEL LINE IN ENGINE COMPARTMENT
- Tire Label mailed to owner. No claim submission by dealer Install tire label (Labels mailed to customer)
- Certification label mailed to customer
- PCV Nipple
- EMISSION CONTROL LABEL
- Electric cooling fan (CANADA ONLY)
- Fuel Pump (Nevada & Calif only)
- Door lock cable adjust
- Fuel Pressure Sensor
- SRS Software Upgrade
- ECM Software Upgrade
- Tire Label on B Pillar
- CRANKCASE VENTILATION HOSE CLAMP
- INTEGRATED BOOSTER SEAT LABELS
- PEM REPLACE & RELOCATE
- INSPECT OR REPLACE MASTER CYLINDER
- Replace Roof Rail Bolts
- Inspect Motor Mount Bolts if necessary replace bracket EXTENDED WARRANTY FOR FUEL PUMP
- Engine Management Software Extended Warranty
- Power Steering Return Line Hose Check and or replace PZEV Vehicles Oil Trap and Crankcase Ventilation Hose PCV OIL TRAP AND VENTILATION HOSE
- CEM SOFTWARE UPGRADE FOR WIPERS
- ELECTRIC COOLING FAN MODULE
- CEM SOFTWARE TO CORRECT POSSIBLE STALLING DRIVERS SEAT SIDE COVER
- REPLACE HEADLINER
- FUEL LINE RAIL COVER
- Fuel Pump Recall Advisory Extended Warranty (Hot States) Fuel Pump Extended Warranty (Cold States)
- Inspect / Replace Fuel Pressure Line
- 2 Tire Pressure Labels & 1 Owners Manual label
- TORQUE GEARSHIFT LEVER STUD ASSEMBLY
- TIRE AND OWNERS MANUAL LABEL
- DRIVERS AIRBAG CLOCKSPRING SHIM
- Steering Gear Extended Wty 7 yrs unlimited miles
Last Updated on October 22, 2024
