This topic has 47 comments in the Volvo forum.
ECC Climate Control Temp Sensor Measurements Made Easier
I’m in the process of trying to figure out why the ECC climate control system on my ’97 855 GLT (158k miles) is unhappy and blinking its AC and REC lights at start up. As best I can tell the system functions as intended: AC is cool, fan blows normally, temperature tracking seems ok, position knobs for upper and lower vents direct the air properly, the recirculation switch makes the damper move into recirculate mode, etc. I’m just going through the system checking out components to try and find one or more that isn’t working right.
 jreed » I’m in the process of trying to figure out why the ECC climate control system on my ’97 855 GLT (158k miles) is unhappy and blinking its AC and REC lights at start up. As best I can tell the system functions as intended: AC is cool, fan blows normally, temperature tracking seems ok, position knobs for upper and lower vents direct the air properly, the recirculation switch makes the damper move into recirculate mode, etc. I’m just going through the system checking out components to try and find one or more that isn’t working right
Troubleshoot Flashing AC And Rec Lights On Your Volvo’s Electronic Climate Control System
Part of the process was to check that the two duct temperature sensors and two interior cabin sensors are working. Maybe somebody else already discovered this method, but I hadn’t come across a write-up anywhere, so it was new to me: I found a way to do the resistance test on all four sensors relatively easily (no removal of sensors or disassembly of lower part of dash is required for this test — though like me you may already have removed the panels and glovebox, etc, to check everything else out). All you have to do is to pull out the ECC control module from the dash, disconnect the three green connectors on the back. (Removing the radio first makes it easy to push on the back of the ECC module to release it from the panel).Remove the three green connectors on the back of the ECC module.Remove the three green connectors on the back of the ECC module.
With the connectors disconnected from the module, take the large connector in the middle and locate the brown, yellow and green wires on the back.Brown, Yellow and Green wires going into back of large connector.
Measuring the resistance of one of the Cabin interior temperature sensors (the Brown-Green pair)
Above I’m measuring the Green “#2” connection (my #1 and #2 labeling numbers are arbitrary — I don’t know if green is driver’s or passenger’s side) and getting about 7.7kOhms resistance, which is close to the 8-12kOhms range described in the helpful “850 -95 AC Heater System Manual” pdf file. I figure I was reading 7.7kOhms because it was pretty hot outside when I was doing this test (~85-90F) and the pdf mentions that the resistance declines with increasing temperature.
Below I’m measuring the opposite side of the car (the Brown-Yellow pair) and getting 7.56kOhms.
Measuring the resistance of the Brown-Yellow (GND - #1) sensor
Next I’m measuring the duct temperature sensors. The wires for these sensors are on the small green ECC connector that only has four wires going to it.
Duct temp sensor test
Here I’m measuring the Brown-Yellow pair and getting 8.3kOhms. I measured the Brown-Green pair and got a similar value.
Just thought I’d write this up as a quick and handy test to allow measuring all four of the interior temperature sensors in a relatively quick and painless way. All four of my temp sensors appear to be reading roughly similar values. I also checked that the fans located behind the cabin temp sensors appear to be spinning normally.
The fifth sensor in the AC system is at the bottom front of the car mounted to a metal tab right in front of the radiator (on my ’97 — I think ’95 and earlier have a different type of sensor that is located near the windshield on the passenger side). When I tested that sensor I got about 500 Ohms, which matched the reading of the second temperature sensor located just above it in front of the radiator.
ECC climate control temp sensor measurements made easier
