Location of the keyless drive antennas
Keyless drive antennas on 3rd generation (P3) XC70
The keyless drive system has a number of antennas located at various points in the vehicle.
  • On the tailgate, near the wiper motor
  • Left rear door handle
  • Ceiling, above the center of the rear seat
  • Under the floor of the cargo area, near the rear seat
  • Right rear door handle
  • Under the rear section of the center console
  • Under the front section of the center console.
Image 1 -
Keyless Drive System Explained
  • This system makes it possible to unlock and lock the vehicle without having to press any buttons on the Personal Car Communicators (PCC). It is only necessary to have a keyless drive remote key in your possession to operate the central locking system.
  • Both of the PCCs provided with the vehicle have the keyless function, and additional ones can be ordered. The system can accommo- date up to six PCCs.
  • The red rings in the illustration indicate the area around the vehicle covered by the keyless drive antennas.
  • If the PCC does not function normally (weak battery, etc.), the vehicle can be unlocked with the detachable key blade
Keyless drive information messages
If all of the PCCs are removed from the vehicle while the engine is running or if the ignition is in mode II and all of the doors are closed, a message will appear in the instrument panel display and an audible signal will sound.
When at least one PCC has been returned to the car, the message will be erased in the display and the audible signal will stop when:
  • A door has been opened and closed
  • The PCC has been inserted in the ignition slot
  • The READ button has been pressed.
