Melt Tires, Not Pistons! A/F Mix… FF#28
ARD tuner Robert “Lucky” Arnold tells us why 14.7 is the 3.14 of car tuning.
Do not melt your pistons: Air Fuel Ratio: It Matters
To start we should understand that there is an ideal mix of gasoline and air that is desirable for the most complete combustion. This ideal mixture is referred to as the stoichiometric ratio and for typical gasoline engines it is calculated at 14.67 or rounded to 14.7 parts air to 1 part fuel as measure by weight. This ratio provides the most efficient combustion with the least pollutants.
An AFR higher than stoich = lean. An AFR lower than stoich = rich. A lambda value higher than 1 = lean.
summitracing.com
Now with that said the stoichiometric mix of air/fuel has changed some over the years partly due to the addition of ethanol into the fuel and partly due to additives that are added to the fuel. This puts the ideal AFR closer to 15.2 parts of air to 1 part of fuel. That’s right, the engine can actually use less fuel at idle and light throttle cruise than it used to, due to these additions in the pump gas we typically see here in the states. With the right type of gasoline, you do not melt your pistons.
14.7 is the 3.14 of tuning.
Matthew
Air Fuel Mix
In summary, Volvo recommends that owners utilize detergent gasoline to prevent buildup of engine deposits. Detergent gasoline is very effective in maintaining injectors work without friction and help ensure that the intake valves remain clean. When Volvo owners regularly use detergent gasoline, this ensures good fuel economy and car handling. If you are unsure about the type of gasoline for your volvo, always check your owner’s manual or speak to the operator at the service station.
Last Updated on February 14, 2021
