Suspension Rattle S70 T5
jblackburn »
For about a week now, I have noticed what I can only attempt to describe as a quiet ‘clunking/rattling’ noise from my front left suspension when I go over slight bumps in the road. Sorry I can’t be more descriptive, but the noise is definitely getting louder, especially after a long trip this weekend. It’s getting worse; it sounds like my tire’s going to fall off on rough roads. I’ll be the first to admit that I know nothing about suspension – I think the front struts are probably fine (for now anyway), and the front axles were both replaced about 2 years ago. What could this be? Spring seats? Strut mounts? Control arm?
Red-Arrow »
It really does sound like the spring seats are shot. Replace both front ones at the same time.
I have a metal rattle from the rear end and I have check everything on a ramp and all the bushings are tight. I can only get the rattle when I kick the tire side wall hard towards the rear and when the tire is off the ground.
jblackburn »
This was my first attempt at suspension work on one of my cars, and I’ll say it went pretty smoothly for having no idea what I was doing. I’m no longer intimidated by removing the whole strut assembly, although some other parts of the suspension down there can be a royal pain in the rear. I was done with it in under two hours – the worst part was the old, rusty bolts and trying to find a way to keep the broken spring seat still while I cracked the top nut loose; I used the XC90 spring seat over a year ago and it’s been just fine. I didn’t change the other at the time (it was really cold and I was working in my driveway), and as far as I know it is still original.
C@lvin »
My experience with the spring seat on my 98 S70 NA 203K was that it made more of what I would call a squeak or creak when going over bumps. I would not have characterized the noise as a rattle. It sounded more to me like a creaky stair or floor sound. Interestingly, I also noticed that the colder it got outside, the louder it got. On warm days the noise might go away all together.
The PO gave me 99% of the receipts since 20K in 1999 and as best I could tell the car was still running on all original suspension components when I bought the car. I replaced the right front spring seat in 11/07 at 161K and the left front spring seat 30K later in 03/10 at 191K.
I used Febi-Bilstein spring seats from Eeuroparts.com that are $23. At 42K on the first one and 12K on the second one there have been no problems.
My 00 V70 NA 120K is still running on all original suspension (except for a TRW left outer steering end link/tie rod) with no current symptoms of component failure(s).
